Suspension Click Noise
#46
on
I just got my car back from the dealership. There was a clicking noise on my back right suspension. I got a call back from the service manager. He said that For some reason there is a clicking noise that happens on alot of G35's in between 10,000-15,000 miles. He said it is of no concern but they cannt replace the suspension because it could just make clicking noise in another 10,000 miles. They said Infiniti is investigating this and will get back once they have a solution. NO TSB HAS BEEN PUT OUT ON THIS, but the manager said there will be soon. Just giving you guys a heads up.
Thanks - Joey Avino
Thanks - Joey Avino
#47
#48
I notice a click when I shift from Park to Reverse or Park to Drive when the engine is cold. The click definitely comes from the rear of the vehicle. I don't hear the click anytime after that. Do you think the click is transmission related? or has to do more with the Rear axle and the TSB that this thread pertains to?
This is on a 2005 G Coupe with 62k miles.
#49
I have the Infiniti TSB papers. It states as follows;
Applied Vehicles: 2003 - 2005 G35 Sedan (V35)
2003 - 2005 G35 Coupe (CV35)
If you confirm:
A "clicking" noise is coming from the left and/or right rear axle (driveshaft) when accelerating from a stop,
Remove the driveshaft, clean the flange surface of the outer joint on the driveshaft and apply a moderate coat of molykote M77 grease.
Classification:RA05-001b
Reference:ITSB05-007b
Date: December 21st, 2005
If you confirm:
#51
on
Damn clicking
^Same prob as amsterdamned. I have an 06 coupe 5 A/T with 17,250 miles, and I hear a clicking noise when going from park to reverse, reverse to park, reverse to drive, and etc. I have noticed this noise, for a lil bit, but never tripped on it. I noticed in the other post that this applies up to 05, but how about the 06? Still under warranty, I only have 5/16 spacer, and SxExCx grounding kit. Will the dealer take care of this issue? Has this been addressed before? Apologize, if so? Thanks.....
seagrasser
05-03-2022 09:43 AM
magnetism80
02-01-2019 10:00 AM
