Lowering Car...Which Do You All Recommend
Hey Everyone,
I just put on a set of 19" Staggered Setup Aftermarket wheels on my G35 Coupe. I am now going to lower my car. Which would you all recommend out of these 3 and if they are good or not. Please, anyfeedback is appreciated. Thank you all.
http://cgi.ebay.com/ebaymotors/03-06...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/TEIN-...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/EIBAC...QQcmdZViewItem
Both the Tein and Eibach kits are well-known and have decent reputations from what I've read. Do a search in the suspension section for reviews and spring rates. I caution you about lowering springs, though. They will dramatically reduce the life of your OEM damper. If you're concerned about having the car for a while, it might not hurt to go with replacing full coilovers.
definately not one!!!
also be careful when buyin teins on ebay. there have been several cases of counterfeit ones on there. check out www.tein.com for the details
If you want a good drop and a reliable suspension, go with a full coilover. HKS and Tein are the big names, but there's a few others. If you want to stay under $1000, go with Tein Basic coilovers or Tein springs (like #2 above) with Tokico D-spec dampers. If you can only spend a couple hundred bucks, either Tein or Eibach Pro-kit springs (#2 and #3 above) are your best bet. As mentioned above, there have been issues with counterfeit Tein springs on Ebay. I think the only difference you'd have to worry about between the two is the amount of drop you want.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
