another sedan suspension ?
Old May 15, 2006 | 12:48 AM
machavez702's Avatar
I have a situation...I have an 06 sedan with sport package. I added J8 Pro's, 10" wide rear wheels, and will probably have the fenders professionally rolled to minimize rubbing because the tires are rubbing when I have passengers. I also have about 200 lbs of stereo equipment in the trunk which seems to have lowered the car about 1/2" already. I have sway bars too (helps some). This is obviously not a track car, but I do some "spirited" driving on the streets.
I'm looking for a setup that will actually raise the rear about 1/2" if possible. I want to lower the front and that doesn't seem to be a problem. Anyone have any suggestions? Will a coilover set with stiffer springs rate help?
Old May 15, 2006 | 02:10 AM
godmans's Avatar
add energy spacers =) that should help you "raise" the rear..
you can search for "energy suspension spacer" and see what people use for the rear
Old May 15, 2006 | 02:34 AM
absolutg's Avatar
workin...
look @ X springs...
Old May 15, 2006 | 09:49 AM
Chico's Avatar
Post more info on your wheel/tire set up so we can better help you. If you had the right offsets and tires on the 10" you would not rub with or without a heavy load in the rear.
Old May 15, 2006 | 03:16 PM
I'll have to check on the wheel offset & tire size. I'll post that info later, I didn't think it was pertinent because the wheels are already on and rubbing. I'm looking for a solution for this. I tried searching for energy suspension spacer and X springs. I will have to go through a stack of posts to find any info. The search engine is not that helpful. Any info or links to sites supporting the suggestions would be greatly appreciated.
Old May 16, 2006 | 08:48 PM
Tanabe USA's Avatar
That's definitely an interesting setup you are running.
The best option is to go with a height adjustable coilover suspension from a reputable company.
With a height adjustable suspension you will not only have the ability to set the height, but the important ability to properly balance the weight distribution of the car. If you have a facility in your area that can perform corner balancing, you can still have a G that handles well, even with all of the extra equipment in the back.
Most adjustable coilover suspensions have higher spring rates, which may be suitable for the extra weight and shorter suspension travel of your setup. With all of that extra weight, you are going to make the rear dampers do a lot more work, and they will be more prone to failing.
Mixing and matching springs for front to rear to balance the ride height might have undesireable results while driving.
Adjustable coilovers aren't the cheapest option, but they are probably the smartest way to handle your needs with the least amount of hassle down the road.
-Tanabe USA
Old May 17, 2006 | 12:05 PM
vodkarocket's Avatar
Modded Member
For your intended purpose, I doubt that coilovers will work as they won't allow you to retain stock (or higher than stock) height. See this thread for more info, and a link to the energy spacers: https://g35driver.com/forums/showthr...pension+spacer
Old May 18, 2006 | 05:27 PM
Ok, I've read through a lot of posts trying to find a solution for my situation. Let me start by stating I don't now much about the installation of coil overs or spacers. That being the case, I'll ask what may be a stupid question. Can I use a spacer with a coil over kit? Or is the spacer intended and only used for the stock type of setup, springs and struts/shocks?
jsimonk
Dec 22, 2023 03:49 PM
tiguy99
Mar 1, 2016 11:42 AM
si_driver
Aug 11, 2015 07:08 AM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
CJay
Aug 1, 2015 03:57 AM
