ArizonaZCar Wilwood 4-Pot Front BBK Installed
Old May 22, 2006 | 08:10 PM
  #46
geeitup's Avatar
Template is the way to go, but I would be amazed if the 6pot was a problem with 38mm offset
Old May 22, 2006 | 11:49 PM
  #47
urban's Avatar
I am not good at the offset game either but let me guess that the 6 piston will not be an issue with 19x9.5 Volk Challenges??
Old May 23, 2006 | 07:37 AM
  #48
cato's Avatar
SouthernComfort Moderator
According to Discount Tire, 38-45 mm offsets will fit within my fenders. 5Zigen says that with the Wilwood BBK the 35s will also fit. This is because the rotor hats are so much thinner than the stock ones. The dilema is I want to put the wheels on before I install the BBK. With the 35 offsets installed on the stock rotor hats the tires will potentially be sticking out of the fenders. Rub and bump my fenders? OH GOD! why does this have to be so difficult. I really don't need the 6 piston Wilwood BBK as I don't track my sedan. The 4 piston BBK is still a huge improvement over the POS OEM brakes.
Old May 23, 2006 | 06:38 PM
  #49
dklau33's Avatar
Then I'd suggest getting a 17x8 +38 wheel. Most (depending on spoke design) will clear both the 6-pot and 4-pot. The only reason to get the 6-pot for a street application is that it may maintain pad life slightly better than the 4-pot. Also it will give you better street cred because 6 is always better than 4 yo! Seriously though, the 4-pot is huge improvement over OEM and it will save you $300.
Old May 24, 2006 | 02:11 PM
  #50
cato's Avatar
I just purchased 4 5Zigen 17X8 43 mm offset wheels from Discount Tire. The 5Zigen website says these guys weigh in at 18 pounds/wheel. The stock 6 spokes are 23 lbs, so I am shaving some unsprung weight! When I replace those POS front brakes with the Arizona ZCar Wilwoods, I should be way lighter. I expect to really burn rubber now! My 235/50 ZR17 Pirelli tires will fit these wheels perfectly! Can't wait to get them installed. Pics to come.
Old May 24, 2006 | 02:45 PM
  #51
_jb's Avatar
_jb
Photographer
Originally Posted by inTgr8r
one way bleeding valves.
Let you bleed the brakes by yourself
That's interesting. I have never seen anything like these before.
When you loosen them, they bleed like any other bleeder, except that the ball keeps the pressure up when you release the pedal. So, that must be a pretty strong spring and the ball must be a perfect fit to seal the fluid.
Then, once you tighten the bleeder, it seals just as any normal bleeder seals. What a great idea... thanks for the info.
Old May 24, 2006 | 05:19 PM
  #52
dklau33's Avatar
Congrats buddy! You just shaved off 30 lbs of unsprung weight assuming your current tires aren't heavier than the OEM tires. Anyways you will definitely feel a difference in handling and when launching. What color wheels did you get? Be sure to post up your own install thread when you get the new BBK and wheels on.
Old May 25, 2006 | 09:06 AM
  #53
cato's Avatar
I am pretty sure the 235/50 17 tires are a bit heavier than those POS 215s... Who cares? I got the silver with machne faced spoke ones. They might arrive tomorrow, but for sure by Monday.
Old Aug 8, 2006 | 09:10 AM
  #54
cato's Avatar
Wheels arrived and installed. Arizona 6-pot BBK ordered and received. Install this Saturday! Dave at AZC ordered the 6-pot SL calipers that are the same width as the 4-pot.
jsimonk
Dec 22, 2023 03:49 PM
Xfactor
Dec 1, 2019 12:52 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
