Buying, Selling & Leasing Discussion Interested in getting a G35? Ask your questions here! (No Classified Posts)
Help with low mileage (55k) '05 Coupe I'm considering buying
Old Mar 5, 2019 | 02:30 AM
SeedyROM's Avatar
Coupe
Originally Posted by cswlightning
Morimoto makes HID bulbs for $40 a pair that seem to be high quality. They're inexpensive and also from a well-regarded company with excellent quality control at least on their projectors, I'd get them from The Retrofit Source.
I gave a $20/pair 4300k TRS ACME H1 bulbs a shot but one blew after 3 months when I upped its power to 55W so I won't recommend those, although on 35W the light output is excellent with a nice colorful cutoff on my aftermarket projectors.
That is one nice car. Amazing find!
Thanks for the tips, that's good to know about Morimoto as a backup if swapping the bulbs proves one of mine is out. Would be right to assume these are the correct ones? It shows $50 on the site (still a great price), just wanted to confirm.
https://www.theretrofitsource.com/d2...reselect=49499
Old Mar 5, 2019 | 12:17 PM
cswlightning's Avatar
I'm actually not sure the OEM bulb size, I've got aftermarket h1 projectors.
Old Mar 5, 2019 | 02:17 PM
SeedyROM's Avatar
Coupe
Well, everything I've read says it's a D2R for the 2003-2005. I assume it should drop right in but I'll do some more research. Thanks!
2003-2005 G35 w/HID: D2R (Low Beam), H4/9003 (High Beam), Fogs (H4/9003)
Old Mar 5, 2019 | 02:51 PM
In that case you are correct, it'll fit. D2R is D2R!
Old Mar 5, 2019 | 08:55 PM
Scorpi0's Avatar
D2R is for headlights with a reflector.
D2S is for headlights with projectors.
They will both fit but the D2R has a metal plate on one side to block the light beam on that side.
Old Mar 6, 2019 | 03:25 PM
Urbanengineer's Avatar
You shouldn't use D2S in a reflector set up it will have major glare. Nice ride.
Old Mar 6, 2019 | 11:37 PM
SeedyROM's Avatar
Coupe
Yep, grabbed some D2Rs instead, should be all set. Thanks!
Old May 19, 2019 | 01:47 AM
akrkwk310's Avatar
LR G35 coupe 6 speed
Thats good deal!!
G35LikeaG6
Nov 22, 2011 03:48 PM
trunysin
Oct 16, 2010 02:00 AM
PsYcholG35
Apr 24, 2007 02:13 AM
Vince5d
Feb 18, 2007 12:03 PM
Skyliner
Aug 14, 2006 08:39 PM
