Canada Serving Canada.
Rubber Door Molding
Old Jan 23, 2007 | 03:33 PM
white_gts's Avatar
Ok folks I have an update on my issue. I brought my car back to where I bough my car in to the Willowdale dealer and the sevice advisor said it is covered under warranty. He took down my info and created a work order for me and will contact me when the part comes in. I was there for less then 10 mins. He also mentioned to me that this is very common and they have replaced a lot under warranty. So whoever has the same issue as me just bring it in.
I'm glad my dealer is willing to replace it under warranty.
Old Jan 24, 2007 | 02:21 PM
fluffydot's Avatar
I've had both sides of that same molding replaced under warranty also.
I think it was just poorly made and poorly designed piece... oh well.. atleast it was free
Old Jan 24, 2007 | 03:08 PM
giddyup69's Avatar
Originally Posted by lepricon
Hey Guys,
I just had the same thing happen. I went to both Yorkville and Alta and they told me that it was NOT covered under the warranty. They said that it was common for this piece to fall off. It was around $80 for a new piece if I remember, plus the cost to paint it to match your car.
Hope this helps
Dave
u got ripped off... i had mine replaced last year under warranty, no questions asked.
Old Jan 24, 2007 | 07:05 PM
RBull's Avatar
Rated M
That would make sense to me.
Old Jan 24, 2007 | 07:31 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
^+1
I think dealers have problems when they process too many claims of a certain type.
Also, they make more selling it to the client than they get back from Infiniti;
If they can get away with it.
Persistance usually pays off for this type of issue.
Old Jan 25, 2007 | 01:29 PM
white_gts's Avatar
I got the rubber molding replaced today. They told me that they are not going to spray or put my car through the car wash because it is way below -13 today. Service Advisor mentioned to me if it is below -10 dont wash our cars as the windows can shatter and door locks can get frozen.
Old Jan 25, 2007 | 06:51 PM
Mmagic76's Avatar
Shatter? I've never heard of that one... I just washed my car!
Old Jan 25, 2007 | 07:00 PM
RBull's Avatar
Rated M
Neither have I. I also haven't heard of sprain either?
Old Jan 25, 2007 | 08:42 PM
white_gts's Avatar
Sorry I meant to say the dealer was not going to spray=clean my car today. They said that the windows can shatter when you open or close the doors if they are frozen. I guess they think it will happen as our doors have no window frames.
Old Feb 21, 2007 | 04:16 AM
in2win's Avatar
I just had this problem, its from putting your hand/ or foot on it when you are getting out of the car. slowly tears it off. Double sided tape will keep it down...
Old Feb 24, 2007 | 03:55 PM
AthensBlueG's Avatar
Brian
I just noticed this problem today too.
I was cleaning the bottom of the door from the inside with a microfiber cloth, and I think I applied too much pressure (although it wasn't very much pressure at all) as I ran the cloth across the bottom edge of the door. I then checked the other door and noticed I had the same problem there too. The rubber/plastic is pretty brittle and frail, and it wasn't frigid outside when it happened.
here's a pic. I am going to seek replacement parts under warranty. Thanks for the info guys - when I saw the problem on my car I just KNEW someone else had probably posted about the issue too. I love G35 Driver!
Old Dec 15, 2010 | 02:55 PM
G35thrilla's Avatar
ya i have the same problem i'm gonna go check it its covered under warranty. The painted rubber trim under the passenger door started coming off. i dunno why tho.
Old Dec 15, 2010 | 06:11 PM
RBull's Avatar
Rated M
^your warranty is for 4 years or 100K whichever is first.
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
dcsbh1
Oct 1, 2015 03:15 PM
Paragham
Sep 15, 2015 12:04 AM
