Canada Serving Canada.
Need a good wheel and tire place that is open early.
Old Apr 17, 2007 | 08:59 PM
bigwilly's Avatar
I just put on my summers then went around to each tire with the pressure gauge. They were a bit low so I proceeded to add some air, now my front right tire is leaking air at the valve. I don't even have to push the little metal pin in the center and I can hear the air coming out. Right now I put the valve cap back on and I can't hear anything. I will need to check again in a bit. However I probably need a new valve. Can anyone recommend a good tire place that is open early? Around 8 would be good, I want to get it done before going to work.
I am in the Scarborough / Agincourt area. The tires were purchased at Wheels Direct which is pretty close but their website doesn't show store times. I work in Markham so any in the area of Warden and Steeles would be good too.
Thanks
Old Apr 17, 2007 | 09:02 PM
35bills's Avatar
How about the Firestone shop next to Wheels Direct? There a good place. I purchased my snows there.
Old Apr 17, 2007 | 09:03 PM
GEE35FX's Avatar
Thanks
Did you try just tightening the valve stem, it could be a 10 second fix like that to stop your leak.
Old Apr 17, 2007 | 09:15 PM
RBull's Avatar
Rated M
^+1
if you don't have a little valve tightener just use a small needlenose plier. Use very little force to snug.
Old Apr 17, 2007 | 09:33 PM
bigwilly's Avatar
I am attaching a pic of the valve, I have a feeling that this is a cheapie valve that they installed. The base of the valve is rubber and flexible, there is a metal sleave that covers the valve, this actually came off when I was putting air in. I slid it back on, not sure if I did it properly. I don't see how I can twist or turn this valve. The tire is down 1 psi since I checked 30minutes ago, not sure if I can attribute to it still leaking with the cap on or just when I took the cap off to take the reading.
Attached Thumbnails Need a good wheel and tire place that is open early.-valve.jpg
Old Apr 17, 2007 | 09:47 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
It's the core that is in the center when you take off the cap.
Old Apr 17, 2007 | 09:57 PM
GEE35FX's Avatar
And the tool for tightening the valve core is very simple, only costs a couple of dollars.
Attached Thumbnails Need a good wheel and tire place that is open early.-valve-stem-tool.jpg
Old Apr 17, 2007 | 10:09 PM
bigwilly's Avatar
Cool, some tweezers did the trick. Thanks a million guys.
Old Apr 17, 2007 | 10:14 PM
GEE35FX's Avatar
Excellent, you should make a trip to Crappy Tire sometime and pick up a valve stem tool just to keep in your tool box. You never know when one will come in handy .
Old Apr 17, 2007 | 11:07 PM
35bills's Avatar
Great suggestion Wayne!!!
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
