Canada Serving Canada.
Pressure Washers
Old Nov 16, 2007 | 07:26 AM
RBull's Avatar
Rated M
Originally Posted by spudly
I love my gas one. Unlike most people on here I have only a lowly plebian one from Sears, with onyl 6.5hp and 2800 psi. When i bought it 4 years ago it that was a solid .5 horse and 3-400 psi better the other residential models out there. There is more choices now but it works well and consistently for me. And yes i have ventilated a pair of sneakers with it.
Ouch.
Old Nov 16, 2007 | 07:29 AM
RBull's Avatar
Rated M
Originally Posted by Garnet Canuck
Thanks for the suggestions guys. My sister and mother want to go in on the purchase as well, so we'll be able to get him a really good one. My Father won't be using it all that much, just to wash the house, etc. I am wondering if an electric one like mine would be sufficient or if a gas powered would really be needed. Thoughts.
I have a piddly 1400 psi Simonize. It has a mind of its own at times every now and then cutting out or refusing to start. The original nozzle wore out too and new ones are half the price of a new machine.
I'm debating what to get at some point too.
Old Nov 16, 2007 | 11:00 AM
Swivel's Avatar
Moderator
Did someone say "piddle"?
Old Nov 16, 2007 | 11:07 AM
RBull's Avatar
Rated M
^LOL, I did say that.
Old Nov 16, 2007 | 11:22 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
At least with a piddler... you don't have to worry about paint damage too much.
A couple of years ago we had a good laugh when a guy showed up on a job with a ~2' patch of paint missing on his truck door.
Apparently he was washing his truck with a pressure washer...
It got under the paint where there was a chip & peeled a piece right off.
I don't think he appreciated us laughing though.
Old Nov 16, 2007 | 11:56 AM
RBull's Avatar
Rated M
True enough. I never use the pw on the car anyhow. I prefer to grind things into the paint by touching it.
That would have been funny looking at the missing paint. Years ago I did something similar where a bit of clearcoat came off around the door handle of my Prelude.
Old Nov 16, 2007 | 12:03 PM
Swivel's Avatar
Moderator
Your secret to a spot-free rinse?? You should post that in Detailing.
Old Nov 16, 2007 | 12:21 PM
InTgr8r's Avatar
I'll get right on that.
Old Nov 16, 2007 | 04:52 PM
whatacar's Avatar
You're braver than most Ian. I wouldn't touch it with a twn foot, make that metre pole.
Old Nov 16, 2007 | 08:58 PM
Gordgee's Avatar
Administrator
I am thinking about purchasing a pressure washer for my father for Xmas. I currently own a Simoniz 1900 and it's been working fine..........however this is my third Simoniz pressure washer as the previous two were 1800s and died. So, I am quite reluctant to buy him a Simoniz.
Has anyone had good luck with Karcher, or any other brand?
My first pressure washer was a commercial electric rig, bought used from someone that got it from the City (used to wash the fleet vehicles). It was pretty well bullet proof, but big and ugly. When I found someone that wanted it, I sold for more than I paid.
I then went through a few washers from Karcher, both electric and gas and came away unimpressed. The higher end gas Karcher washers aren't bad, but overpriced and the mid range isn't great. The ones with Briggs & Stratton engines suck big time, and I found the one I had was virtually impossible to re-start when hot. That one cost me almost $500 and was a piece of crap! The mid range Honda engine Karcher models are so-so and are the ones usually available at Costco.
What you want in a washer that will last is a pump that has stainless steel plungers and ceramic pistons with available replaceable parts. Get the Honda engines with the red steel shroud (not the black one which is a lower grade). Don't just look at psi ratings. Even the cheapies brag about psi. The GPM at a certain psi is what you look for. Also look for easily replaced guns, wands and nozzles (something that is more difficult with things like Karchers). You can vary the agressiveness of the spray by switching nozzels, and also at the pump. Use a 0 degree nozzle at close range, and you could probably put a hole through something, including your hand!
The washer that I've been using for many years now came from Princess Auto. I think it's the one that goes for around $1000. Pressure washers frequently go on sale there for fair prices, and most are commercial grade with the good Honda engines. They have a range of Consumer to Commercial/Agricultural grade washers to choose from. A good one will last you many, many trouble free years if taken care of.
Old Nov 17, 2007 | 08:48 AM
RBull's Avatar
Rated M
^interesting you mentioned Princess Auto. I thought of them when reading this post. They have a lot of them over there and even an area to test them.
Old Nov 17, 2007 | 08:57 AM
Garnet Canuck's Avatar
Traveling Administrator
Thanks for the info Gord!
Old Nov 17, 2007 | 09:06 AM
RBull's Avatar
Rated M
^there is one here in Dartmouth if you don't have one there.
alessandro
Oct 8, 2015 09:29 AM
9tray turbo
Sep 29, 2015 10:22 PM
blueslatebenny
Sep 23, 2015 01:39 PM
Blindside360
Sep 18, 2015 09:00 PM
