Canada Serving Canada.
Torque wrench at Cdn Tire
Old Dec 17, 2007 | 03:45 PM
RA031524's Avatar
Thumbs up Torque wrench at Cdn Tire
I was at Canadian Tire yesterday. They have their 1/2 drive torque wrench on sale for $64.99.
Just thought some of you would like to know as it seems to be a topic that comes up regularily.
Wayne
Old Dec 17, 2007 | 03:50 PM
Swivel's Avatar
Moderator
Good catch, Wayne, I picked one up last time they went on half price. Seems to be a sturdy unit and came in very handy when I changed over my wheels to winters.
Old Dec 17, 2007 | 04:08 PM
QuadCam's Avatar
just picked up a SnapOn Tech Wrench.......3/8" digital torque wrench. 2% accuracy with a range of 5-100 ft-lb!!! Nissan specs the torque on the wheel studs to be 80 ft-lbs. actually, I don't think anything on this car needs over 100 ft-lbs of torque.
Old Dec 17, 2007 | 05:21 PM
Comatose's Avatar
I think i picked up mine from HomeDepot a while back when it was on sale. Like the previous poster, the heaviest i ever need to torque is 80lbs/ft for the wheels. The prob with the one I got however was it doesn't support the lower ranges (e.g. for spark plugs etc)...
They're also pretty cheap at tirerack (30usd), but im unsure of its quality..
Old Dec 17, 2007 | 05:33 PM
GEE35FX's Avatar
If you own a bigger vehicle such as a 4x4 you might have to go higher. I have to torque my truck wheels to 140 ft/lbs (it's a GMC Z71 Extended Cab P/U.)
Also a 1/2" is a bit better when you are torqueing 80 ft/lbs or more because they are longer and therefore you have more leverage and it is easier to use at the highers ratings.
I do have a 3/8 dr besides my 1/2" drive for doing lower torques.
Old Dec 17, 2007 | 09:07 PM
Msedanman's Avatar
O.F. Administrator
Wayne
Thanks, Wayne - that's a good deal too. I saw that their 3/8th drive wrench is also on sale.......
C.
Old Dec 18, 2007 | 01:50 AM
XuperXero's Avatar
Got mine from Princess Auto last year on sale for $25. Reg price was $89.99 I believe... But it's still working fine to this day, I've used it many times at track and changing to winter tires.
Crossmember bolts are suppose to be torqued to 120lb/ft btw. Lucky for me, mine goes up to 150 lb/ft, came in handy when installing the Tanabe Underbrace.
Old Apr 21, 2008 | 05:56 PM
cc101's Avatar
Can anyone confirm QuadCam's 80 ft-lb for the 04 G35 Coupe wheel stud? Sorry, i can't seem to find it in the manual.
Old Apr 21, 2008 | 06:12 PM
GEE35FX's Avatar
Yes
Old Apr 21, 2008 | 09:00 PM
RBull's Avatar
Rated M
I think it's actually 72-80lbs.
Old Apr 21, 2008 | 09:11 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
^ +1 with above.
Also, don't forget to re-torque after 50-100km.
As the wheel & rotor re-seat themselves you will often find one or two loose nuts when you re-torque
Old Apr 21, 2008 | 09:23 PM
gary c's Avatar
Got mine at....
If you don't have a torque wrench in your tool box you should never work on
your G35! Almost all major nuts/bolts have torq requirements, my wheel
lugs are set at 80 too. I got my torque wrench at Sears several years ago
so I don't recall the price. That Snap On wrench is the best on the market,
it actually beeps when setting is reached, way more fun than a click....
Old Apr 22, 2008 | 07:02 AM
whatacar's Avatar
Soooow, what happens if some tire jockey torques your nuts to 95 - 100?
Old Apr 22, 2008 | 07:55 AM
InTgr8r's Avatar
IDK about you but I'd scream like a girl.
Old Apr 22, 2008 | 08:11 AM
RBull's Avatar
Rated M
Too many of them do. You drive down the street with a jiggle in your wheel.
