cheaper gas?
cheaper gas?
i know that gas prices has dropped alot recently but i have been noticing i been getting less km a full tank. is this happening to everyone because of the weather? in the back of my mind tells me that YES, the gas is lower but i think the gas stations might be scamming us and giving us cheaper gas.
I'd say it's like Deane says: Longer warm times and related issues.
We run windshield defrosters/defoggers almost constantly now in winter months which is similar to running your A/C in the summer--- (the a/c part of defrosting is used to dehumidify the intereior of the car)...
......Also using more electrical appliances such as blowers, rear defoggers, seat and sterring wheel warmers will put more load on the alternator causing more of a drag on the engine.
Slippage in snow and ice, engagement of VDIC systems -- all these things add up to more gallons per miles than in the summer or should that be more liters per hundred kilometers....
Cheers, and spring is on the far horizon......
Colin.
Colin.
Winter gas often has alcohol mixed in as a "bonus" gas-line antifreeze. Depending on the concentration your consumption will increase due to the lower BTU content in the alcohol portion of the fuel. Combine that with longer warmups (engine spends more time running rich) and PRESTO! poor economy.
Premium $0.83 in YYC today.
Yup, rather kill fuel economy than anything/one else. I once stopped 4 cm short of where I needed to. Went that far into a bus, could tell because the bus doors told the story. My van ended up where the rear doors were/used to be and towards the back ... and did LOTS of damage to the bus and the car. Luckily, no personal injuries.
RemmyZero
V36 DIY
04-23-2018 11:13 AM
FS[NorEast]: New OEM G35x Compression Rods - Save!!
The Fixer
Steering & Suspension
11-01-2015 03:26 PM
Hogbone
09-28-2015 06:44 PM
