Canada Serving Canada.
bit of a weird question but..
Old Jan 17, 2009 | 05:37 PM
exwrx's Avatar
what engine do i have? car is a 2004 g35 sedan with a 6spd. lol i am interested in knowing what i have and what the differences are between the motors are.
thanks and please dont laugh. !!!
Old Jan 17, 2009 | 05:39 PM
lekker_droom's Avatar
VQ35de - 280hp non-RevUp.
Old Jan 17, 2009 | 08:13 PM
exwrx's Avatar
ok thanks i thought it was 260hp cool. now my question is a motordyne mrev2 a good buy? i would like to make as much power with a n/a car. i have bought a cobb access port already and plan on getting it tuned i guess to exact mods.
Old Jan 18, 2009 | 04:56 AM
no, not for your engine. just get the plenum spacer.
you might want to wait on tuning until you've done a little more with car.
Old Jan 18, 2009 | 05:36 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
wrong...
as long as you get a tune afterwards, the MREV2 + Spacer has been proven to be a great addition to any year G35 versus just installing a spacer.
-GP-
Old Jan 18, 2009 | 08:31 AM
RBull's Avatar
Rated M
Actually here is the correct answer:
The '03 & '04 sedan is officially rated at 260 hp and 260 ft. lbs torque. The coupes are rated at 280 hp and 270 ft. lbs torque. However it's well accepted the sedans are under rated and have the same engine as the coupe. I believe there have been many dynos proving this. The sedan is also slightly lighter by 50 lbs (depends on model/options).
I'll let others debate the Mrev2. I have the 5/16 iso thermal spacer with the copper TB spacer which seem to work fine. Bolt on mods to the VQ give very marginal gains.
Old Jan 18, 2009 | 09:07 AM
GEE35FX's Avatar
Bill, have not seen you on the board for a while. We should get together once this bloody snow disappears.
That was excellent info posted by RBull above.
Old Jan 18, 2009 | 10:15 AM
exwrx's Avatar
hey wayne, i have been lerking around for the last couple months on here keeping quite haha. now i am trying to figure out what is best more me with plenum spacers or the mrev2 manifold. ya we should meet up some time for coffee or dinner some time.
so is it worth getting the mrev2 for a non revup motor or is a 5/16" spacer just as good.... i am sure thats been asked before but what do u guys think about it.
Old Jan 18, 2009 | 11:48 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
I had the complete Motordyne package on my '04
- started with the spacer
- added copper iso thermal
- then the Mrev2 manifold
They were all beneficial & noticeable, but not to the point were you say OMG
The spacer def gave a little more punch.
The iso-thermal helped minimize heat soak for cooler air.
The Mrev2 helps to balance the breathing on the front pair of ports,
the OE is definitely restricted in that area.
Unless things have changed, the Mrev2 actually worked better on a non-revup motor.
Old Jan 18, 2009 | 11:59 AM
exwrx's Avatar
i am having a hard time deciding i should get just a spacer or just a mrev2 or both together..... what are some true hp and tq gain numbers... like i said i am not planning on boosting my car so its just simple bolt ons and a ecu flash for this car.
Old Jan 18, 2009 | 12:03 PM
35bills's Avatar
Hey Bill,
I didn't think that COBB had the Access Port out for early sedans?
I just checked out their website and didn't see any updates regarding this. It said that the current port did not support '03 and early '04 sedans....
Old Jan 18, 2009 | 01:06 PM
exwrx's Avatar
ya it works on g35 sedans with the build date of may 2004 and up.
Old Jan 18, 2009 | 01:53 PM
If you only want one or the other, then get the spacer. But both will provide a benefit, especially with a good tune.
-GP-
Old Jan 18, 2009 | 01:56 PM
exwrx's Avatar
ok say i only get the 5/16" spacer, which model is best for a daily driver in the summer only. basic-iso-copper???
Old Jan 18, 2009 | 03:09 PM
RBull's Avatar
Rated M
Your answer is right here from the horse's mouth.
https://g35driver.com/forums/intake-...ould-i-go.html
