LEDs installed!
LEDs installed!
I just took some pictures of the LEDs I've installed. I bought them from superbrightleds.com site. The LEDs are pretty bright at night. I've provided the parts below that I used. Here's the info:
URL: http://superbrightleds.com/
Rear Sidemarker
Quantity: 2
Product: WLED-xHP5 Wedge Base Bulb $ 5.95 (each)
Options: White WLED-WHP5
Front Sidemarker
Quantity: 2
Product: WLED-x4 LED bulb $ 1.59 (each)
Options: Amber WLED-A4
Back-Up/Reverse Lights
Quantity: 2
Product: WLED-WHP15-T Wedge Base Bulb $ 16.95 (each)
Options: Cool White WLED-CWHP15-T
Headlight Strips
Quantity: 2
Product: WLED-xLX 1Watt LED Wedge Base bulb $ 9.95 (each)
Options: Cool White WLED-CWLX
Trunk/Cargo area
Quantity: 1
Product: T13-x6 Wedge Base LED bulb $ 1.99 (each)
Options: White T13-W6 1.00
License Plate Light
Quantity: 2
Product: 921-x12 Wedge Base LED bulb $ 3.95 (each)
Options: Cool White 921-CW12 2.00
Map/Dome Light
Quantity: 2
Product: 3022-x4 LED Festoon bulb $ 1.89 (each)
Options: Cool White 3022-CW4 0.95
Step/Courtesy light
Quantity: 2
Product: 3022-x9 LED Festoon bulb $ 2.95 (each)
Options: Red 3022-R9
The lights looks purple/blue, but it's bright white when you see it in person.
Rear Sidemarker
Quantity: 2
Front Sidemarker
Quantity: 2
Quantity: 2
Headlight Strips
Quantity: 2
Trunk/Cargo area
Quantity: 1
License Plate Light
Quantity: 2
Map/Dome Light
Quantity: 2
Step/Courtesy light
Quantity: 2
You can probably try putting a strip LED on your license plate...
Jeff at Audio Heaven will hook you up!
Yeah, most of the lights are plug&play:
Parking/city lights or clearance strip
Reverse lights
License plate
Front Sidemarkers
Map Light
Courtesy
The rest, I'm not sure if they are DIRECT plug&play, but those definately are.
Just consult the Sylvania bulb replacement guide to make sure the LEDs replace the right #bulb and you're set.
It's not that hard install...I had to take out the tail lights..there's 3 bolts that you need to unscrew for one tail light...
I replaced my reverse lights twice...since the first led light wasn't bright enuff at night...
This thread helped when I was removing the tail lights:
https://g35driver.com/forums/body-in...ail-light.html
Looks good!
