Canada Serving Canada.
Pro's and Con's about G35
Old Jan 5, 2010 | 07:08 AM
  #46
RBull's Avatar
Rated M
Originally Posted by Monky
Good thread! I am looking at a 08 G35x and wanted to find out the pros/cons of a G. Looks like most of the issues are realtively minor besides the oil leak issue with the engines. Are there oil pooling issues in the 07 and newer models? Coming from a 2nd gen TL, good to hear no major tranny failures.
How's the AWD systems on these cars for reliability?
Not sure what oil leak / oil pooling issue you're referring to?
Are you referring to the oil burning issue with some first generation cars - mostly '05+ rev up engines?
There are no known major issues with the second generation car I know of. Probably the worst is some owners of x's (including me) complain of brakes that vibrate at higher speeds or on significant downhills.
Old Jan 5, 2010 | 10:04 AM
  #47
Monky's Avatar
To clarify, I wanted to know if the oil pooling on the valves in the gen 1 G's are happening with the 07/08 G35's. I would guess the G37's does not have that issue as it is a completely new engine.
Is it the brake pads again that are giving problems? Can changing to after market brake pads resolve vibration issues? I will make sure I test that.
Old Jan 5, 2010 | 10:09 AM
  #48
WhosUrBuddiee's Avatar
PROs
-Great looking car
-Lots of modding options
-Good amount of power
Cons
-Cheap, so lots of high school teens are buying them
Old Jan 5, 2010 | 09:12 PM
  #49
RBull's Avatar
Rated M
Still don't know about any oil pooling issue with the valves.....Never heard of that before. What is it and what cars/ years are you talking about?
Might be pads....might be rotors...seems to be some conflicting info out there.
Testing it will only give you a read at that particular time and it may start 10k later. OTOH it may not be an issue at all.
Old Jan 5, 2010 | 11:00 PM
  #50
Monky's Avatar
https://g35driver.com/forums/g35-sed...ml#post4789747
Check out the oil pooling issue. Hopefully it is not on the 07/08 G35's.
Old Jan 7, 2010 | 07:07 AM
  #51
RBull's Avatar
Rated M
^thanks for that. Seems a few owners are having that problem.
I've not heard of it for the '07 & '08 however this is a different engine from the 2 in the first generation.
G/L with your '08.
Old Jan 7, 2010 | 09:42 AM
  #52
Monky's Avatar
G/L with your '08.
Do you have info on the engines? Nissan actually implemented an engine for 2 years only for 07/08? I thought the engines were the same from 03 to 08 but they managed to squeeze out more HP.
Old Jan 7, 2010 | 09:45 AM
  #53
InTgr8r's Avatar
Staff ALUMNI (retired)
G/L with your '08.
Same here Deane.
I've heard of this on 1st gens, let's hope 2nd gens were corrected.
TheJanitor6203
The Q - Spot
Oct 6, 2015 10:13 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
lemmy999
Jul 25, 2015 12:13 PM
laksjd84
Jul 24, 2015 05:12 PM
