Canada Serving Canada.
UR Crank Pulley.....is it worth it??
Old Jan 23, 2010 | 10:43 AM
G-MAN (CANADA)'s Avatar
I thought I would find it on the Mod forums but no luck so I'll ask here. I have an 04 Sedan 6spd, mods so far AEM CAI, 5/16 Plenum spacer, coupe Mid, Y-pipe, headers, Res. Test pipes. I have a chance to buy a UR Crank pulley ($60.) for those that have this is it a gain in HP or a worthless mod? If someone could give me their input ASAP I'm supposed to pick it up tomorrow.
Thanks
Old Jan 23, 2010 | 10:50 AM
herrschaft's Avatar
I have an 06 5AT. Just had the UR pulley kit installed and dyno-tuned at the same time. They said the pulleys gave me no gain.
Old Jan 23, 2010 | 12:06 PM
WOW no gain?? that would be something I would write to UR about, you must have spent at least $300. between the kit and installation that would have me fiurious.
Anyone else experience the same results?
Old Jan 23, 2010 | 12:52 PM
red35's Avatar
From what i have read the Ur pulley has no gains and can even wreck your crank from so info i have found on my350z. They only ones that are worth while are ATI and Fluidampr. They are harmonic damper that help out more in mid to high hp cars. They are a little more. I just picked up a ATI for 350 US. Do a search and you can see some of the threads.
Here is one
http://my350z.com/forum/forced-induc...91-damper.html
Old Jan 23, 2010 | 01:51 PM
hmm ok, so it looks like its not a good choice even with the good price.
Old Jan 23, 2010 | 04:04 PM
herrschaft's Avatar
I wasn't expecting HP gain, just being able to rev slightly faster.
After reading that thread, I thing I might take off my UR set.
Since I'm reving past 7K rpm.
Old Jan 24, 2010 | 09:01 AM
caketech's Avatar
i'm skeptical of most light weight pulleys, you really have no idea how balanced they are.
Old Jan 24, 2010 | 09:07 AM
exwrx's Avatar
pulley's are not worth dick all. i had a crank pulley on my wrx and wanted it off the car the entire time i had the car.... save your money or buy some gas!
Old Jan 25, 2010 | 08:10 AM
knight_yyz's Avatar
i think they only show gains on a turbo or a nitrous setup. I noticed my engine seems to run a bit smoother with the lightened pulley.
Old Jan 25, 2010 | 09:27 AM
Msedanman's Avatar
O.F. Administrator
Roy, From what I've read, all that the pulleys are good for on these engines is quicker revving but what far outweighs that benefit is that they can upset the delicate balance of the engine and cause some strange and destructive harmonics of the already well balanced VQ.
I've used balancers b4 on American iron which is not as well balanced, but would not on the G's engines, nor any other Japanese engine.
Put the $$ into something else.
Colin.
Sorry Knight, but I had to share.
Old Jan 27, 2010 | 08:20 PM
zeidik's Avatar
hope u got it! its worth every penny! at the very least even tho no power gain, which is weird cuz its gave me 2-8whp all through out, it stresses ur engine less, its a moving part that should be about 7-9lbs lighter then stock, and at the time i had an 5AT as well.
Old Jan 28, 2010 | 12:25 AM
Sylvan lake V35's Avatar
You must not have read the link provided
Over time the UR can cause premature bearing failure due to it not being balanced, I run an ATI myself and it is underdriven but also balanced. As red35 stated the are a few hundred bucks and are heavier than stock so on a stock engine you would likely not see performance gains.
Old Jan 31, 2010 | 06:04 PM
zeidik's Avatar
i have AMS lightweight pulleys didnt have a problem for 90k. still good.
Old Jan 31, 2010 | 06:52 PM
Thanks
so you don't actually have the UR crank pulley he was asking about but instead you have a complete set of AMS under drive pullies.
Old Feb 1, 2010 | 02:42 AM
zeidik's Avatar
yea i have the set from AMS, i assumed it would be the same as the UR pulleys...??? if it isnt my bad!
06g35
Feb 14, 2022 05:59 AM
brianuc4
19
Apr 10, 2020 02:12 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Visionnn
Oct 3, 2015 05:16 AM
sullivan72
Sep 22, 2015 11:39 PM
