Canada Serving Canada.
Changing Wheels
Old Oct 20, 2004 | 04:13 PM
garygrun's Avatar
Changing Wheels
So I've got winter rims and tires ready to install on my new G. Do I use the trunk jack one at a time? Do I buy a decent floor jack? If I buy the jack how do I position it. Can I change 2 wheels at a time? I would appreciate your advice.
Regards
Gary
Old Oct 21, 2004 | 12:02 AM
35bills's Avatar
Re: Changing Wheels
garygrun,
As for myself, I invested in a floor jack some years ago. Its much easier to change your wheels using a floor jack rather than the trunk jack that comes with the G.
If you look in your owners manual, it shows the "jacking points" of your car. I only change one wheel at a time, that way I don't have to use any jack stands.
Another saftey precaution is to use wheel blocks just to prevent your car from rolling.
It usually takes me about 45 minutes to change over to my snows.
Good Luck
35BILLS
Old Oct 21, 2004 | 12:39 AM
Gordgee's Avatar
Administrator
Re: Changing Wheels
A good floor jack is an invaluable tool. You don't need a real fancy or light one (like aluminum), just make sure it's well made. Reasonable priced ones can be had at Costco, etc.
It's difficult to jack up the two front tires off the ground at the same time since the central jack point is difficult for most jacks to reach. Both rears can be lifted by lifting the differential. Jack stands are always good safety items, so you may want to add this to the cost.
BTW, a few have found out the hard way (jack collapsing) that the OEM jack is only for occasional use for emergency roadside changes only.
I have a thread called 'Jacking your G' in the FAQ forum.
<font color=blue>[i]GroundingGear™ Equipped </font color=blue>
Old Oct 21, 2004 | 05:45 PM
garygrun's Avatar
Re: Changing Wheels
Thanks for the info. I'll check out the FAQ. I don't believe that the manual refers to a floor jack - only the trunk jack. I'll read the FAQ first.
Regards
Gary
Old Oct 21, 2004 | 05:55 PM
garygrun's Avatar
Re: Changing Wheels
I read the FAQ.
If I read this right it's easiest to use a floor jack one wheel at a time by locating it at the side rimmed jack points. I will need to design a plate for the floor jack to avoid damage to the rim.
I can do that!
Regards
Gary
Old Nov 8, 2004 | 02:29 PM
QRAFTWERKZ's Avatar
Re: Changing Wheels
To make life easier I also sell a tool which adds about 200lbs of torque to the nuts on removeal, its an indespensible tool for anyones tool box, or to even carry in the car. The wrench is extendable and has various attachments 19-21mm, saves you alot of bone wrenching , knuckle killing tire jobs. The handle extends to 21".
I wish I had this tool in my earlier days.
It retails for $29.95 I have them in stock.
Old Nov 8, 2004 | 02:30 PM
QRAFTWERKZ's Avatar
Re: Changing Wheels
PIX
Old Nov 22, 2004 | 01:31 AM
Gordgee's Avatar
Administrator
Re: Changing Wheels
If there is a Princess Auto near you, they have the flat grooved rubber adapter that fits most of the larger floor jacks for about $10. Direct replacement for the stock saddle. Doesn't crush the rails under the car since it spreads the load.
Xfactor
Dec 1, 2019 12:52 PM
wuppiedog
Aug 7, 2015 11:16 AM
kinetek
Aug 3, 2015 04:25 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
atk08
Jul 30, 2015 03:12 PM
