Canada Serving Canada.
Block Heater Cord
Old Oct 18, 2011 | 10:03 PM
Travellin007's Avatar
Block Heater Cord
Some critter(s) got into my engine compartment spring of last year. The heater cord got chewed up pretty good (thankfully it was only the covers on other wire harnesses). I had the car in the Milton dealership last fall and their price was something like $250, I passed.
Lo and behold, it was a cold winter and could have used it quite a few times.
I'm wondering if there is a good shop around Guelph/Kitchener area that does this at a reasonable price. Then again, it just might be a DIY? I've had no luck in looking into this.
Any info appreciated. Thanks.
Old Oct 19, 2011 | 09:20 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
I can't remember what Infiniti uses for a block heater, but most of them are a standard unit with separate cord.
Have a look at the element & see if it can be detached.
You may be able to get a replacement from crappy tire.
Old Oct 19, 2011 | 10:26 AM
GEE35FX's Avatar
^^+1 , I was just thinking the same thing.
Old Oct 19, 2011 | 03:59 PM
nitish21's Avatar
Lol that cable in the photo looks like a simple computer/TV power cable..I might be wrong though but if it is u can't get those for like $12
Old Oct 19, 2011 | 04:05 PM
InTgr8r's Avatar
^it's different, but the same idea though.
Old Oct 19, 2011 | 04:07 PM
redpearl99's Avatar
the block heater uses an ordinary power cord....you can install the power cord from your computer and it should work fine
Old Oct 19, 2011 | 10:13 PM
audiophool's Avatar
Um, no.
Computer cords use IEC320 connectors. Different from block heater. Block heater cords are designed to operate in higher ambient temperatures found under hood also. Ian nailed it, above.
Old Oct 19, 2011 | 10:22 PM
redpearl99's Avatar
i meant it's the same outlet type, not that the end connector is the same
Old Oct 20, 2011 | 01:18 PM
Thanks everyone. I'll take a look underneath, looks like it should be easy to do.
Appreciated!
Old May 5, 2012 | 11:16 AM
NYT's Avatar
NYT
Can the block heater be removed?
Old May 5, 2012 | 11:50 AM
audiophool's Avatar
Of course it can, but unless it's leaking why would you want to?
Old May 5, 2012 | 12:57 PM
NYT's Avatar
NYT
Save some weight?? I have no use for it.
Old May 5, 2012 | 08:35 PM
audiophool's Avatar
An in-block (core plug) block heater and cord weighs about as much as an iPhone. If you want to save that weight, go ahead and pay $150+ to have it swapped out.
Old May 6, 2012 | 01:18 AM
N1Asian's Avatar
i got a used block heater cord to sell if you'd like?
Old May 6, 2012 | 10:04 AM
NYT's Avatar
NYT
Bummer, thought it might be an easy way to remove some weight (especially in the front) from this tank. Guess I'll save my money and buy the lighter/better Galaxy SIII
I'll probably just take out the cord next time I'm in the front end. No need for it dangling around doing nothing.
Marlin84
Apr 1, 2020 12:52 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
BradMD_96
Oct 6, 2015 09:31 AM
