And now MY carPC install thread!
Old Apr 12, 2006 | 12:00 AM
  #61
rcdash's Avatar
I have the old version of the screen. The back plate is essentially a rectangular piece of aluminum with a notch cut out where the magnet screws in. I extended the length of the notch so I could move the magnet up a little more.
If the magnet is at the right height, it holds VERY strongly. You need to have the metal plate attached properly to the cubby lid first though. If you stripped the screw, then you need to somehow fix that - plastic repair or superglue the metal thing on - or get a slightly bigger screw? Be gentle with those little screws...
My magnet could also be adjusted by rotating 180 degrees - that helped a lot but not quite enough to be 100% secure, so I did a little "extending" with a dremel.
Blowing a fuse doesn't sound good - I know this doesn't help, but something is likely not wired right!
Hey what are u doing trying to get this done on a week day, anyway...
j/k - good luck getting it all fixed up right quick.
Also, Mike in the CarNetix forum is very helpful. He even set me up with some custom firmware parameters (I wanted to change the deadman timer).
Old Apr 12, 2006 | 11:46 AM
  #62
amthar's Avatar
The fuse thing was my mistake. I had the inputs for the P1900 still hooked up and I had the top of the P1900 taken off (but fan still connected). I think I touched the top of the P1900 to one of its capacitors or some component on the board. All I know is I saw a spark and BOOP, fuse dead. When I swapped in another P1900 (and actually had it all put together properly), it works like a champ.
The PC is now in my glovebox successfully powering up and shutting down with the car's turn on & turn off. Screen is working well. Navigation is 100% functional. Tonight I work on straightening up wires and running the wifi antenna cables.
Pictures tonight.
Old Apr 12, 2006 | 11:28 PM
  #63
JWise1203's Avatar
Wow that's great to hear dude. I can't wait to see pics. I need to post up a thread of my own with pics. Hopefully it will help some of the sedan guys with their install.
Old Apr 13, 2006 | 11:37 AM
  #64
amthar's Avatar
GPRS/Edge internet works. Just plugged a generic bluetooth USB adapter in, paired it with my cell phone and connected to the internet. Having a buddy send me a file over AIM was about 9KB/sec, so faster than a 56k modem but nothing to write home about.
Old Apr 13, 2006 | 10:32 PM
  #65
JWise1203's Avatar
I am doing the same thing with my Blackberry. While it's not the fastest, it's nice to have the internet on the go (or at least where your phone has a signal).
Old Aug 14, 2006 | 04:16 PM
  #66
amthar's Avatar
Looooong delay. Mostly because I was so dam* frustrated with my USB hubs that I put the whole thing to the side and said "screw it" for about two months.
What's new:
- bought a 4 port belkin usb 2.0 hub... AC adapter says 5v 2.6A, so this one is hopefully a bit beefier than that stupid 7 port zonets I was using.
- The wifi antennas are run to the back window.
- Clifford G5 Concept 450 alarm installed
And I have figured out a way of getting one up on Caelric's install, but I can't say what it is, because he'll run out and do it himself
Old Aug 14, 2006 | 05:24 PM
  #67
caelric's Avatar
Bah! Thats all I have to say about that.
Old Sep 15, 2006 | 09:33 PM
  #68
rcdash's Avatar
The 7 ports are a waste - tried them - not enough power or they are too slow or some d@mn thing like that.
You have to experiment with the 4 port hubs. I now have a CyberPower and a Zonet (1 each) and 1 of those is still giving me trouble but haven't had the time to track it down. Actually lost interest because it works well 95% of the time and a quick reboot fixes it the remaining 5%.
Old Sep 17, 2006 | 06:42 PM
  #69
dovla's Avatar
USB 2.0 or USB 1.1 hubs?
On my laptop in the car, USB (2.0) ports are always powered. I was also having all kinds of problems and frustrations with USB units after standby or hibernation until one day I connected some funny looking Radio Shack USB 1.1 4-port hub to the laptop and then Zonet 4-port USB 2.0 up front so that all units actually have to pass through USB 1.1 hub. Prior to that I tried ALL USB hubs that I could buy in local stores – like 7 or 8 different kinds, devcon also didn’t help. So unless you need bandwidth try putting some USB1 into chain.
Jusseth
Sep 13, 2020 12:25 PM
Xfactor
Dec 1, 2019 12:52 PM
RA081024
Aug 18, 2015 07:03 AM
saskicker32
Aug 11, 2015 02:12 PM
yassy
Aug 9, 2015 07:31 PM
