DigtalWheelz screen problem
Old Apr 10, 2006 | 11:03 PM
amthar's Avatar
this was originally in my install thread, but I wanted to make sure people saw it so I could get as much feedback as possible from those who have used the screen. I am 99.9% sure it's something I've missed or doing wrong, I am still very impressed with the product and would recommend it to everyone still. That being said...
As promised, pictures and video of my problem. the first is the screen shut. You'll notice the black electrical tape holding the left side of the metal cubby lid plate in place because the screw will not screw: http://www.rtpnet.com/screen/DSCN1460.JPG
lid up, screen down, from the front: http://www.rtpnet.com/screen/DSCN1461.JPG
lid up screen down from the top: http://www.rtpnet.com/screen/DSCN1462.JPG
looking down the back of the screen with it opened. You can see how the magnet barely makes contact. Moving the magnet around does not help this problem: http://www.rtpnet.com/screen/DSCN1464.JPG
close up of the lid metal plate: http://www.rtpnet.com/screen/DSCN1466.JPG
you can see how the screw and magnet hit all over this part of the plate, but it does not hold the screen up: http://www.rtpnet.com/screen/DSCN1467.JPG
right side of metal plate: http://www.rtpnet.com/screen/DSCN1468.JPG
left side of metal plate: http://www.rtpnet.com/screen/DSCN1469.JPG
video of screen opening and then my best attempt at showing how the magnet touches (and does not hold) the screen when looking down from above: http://www.rtpnet.com/screen/DSCN1463.MOV (13mb quicktime required) note: I moved the magnet to every single hole location on the back of the screen with no change in holding ability.
Video of screen closing, opening again and my best attempt to show how the magnet touches the metal plate, and provides no holding strength (shown from the passenger side, looking in): http://www.rtpnet.com/screen/DSCN1465.MOV (21mb, quicktime required) note: I moved the magnet to every single hole location on the back of the screen with no change in holding ability.
Old Apr 10, 2006 | 11:47 PM
lawrence's Avatar
magnet will not hold try this
short but sweet
$ 1.95 @ home depot
7/8 or 22 mm screw bumpers ,they come in a 4 pack
shepard part number = 9131
SKU 0 39003 09131 9
holds like a .....
Attached Thumbnails DigtalWheelz screen problem-43630095.jpg   DigtalWheelz screen problem-43630094.jpg   DigtalWheelz screen problem-43630092.jpg   DigtalWheelz screen problem-5.jpg   DigtalWheelz screen problem-86.jpg
Old Apr 10, 2006 | 11:50 PM
amthar's Avatar
omg, ok, did you have this SAME problem?!? Please tell me you did... this would make me feel soooo much better.
Old Apr 11, 2006 | 12:02 AM
lawrence's Avatar
same thing happened to me also fits around the side ducts poorly
had to use some washers at top of bracket.
hope this helps
Attached Thumbnails DigtalWheelz screen problem-30087.jpg   DigtalWheelz screen problem-630088.jpg
Old Apr 11, 2006 | 01:30 AM
amthar's Avatar
Originally Posted by lawrence
short but sweet
$ 1.95 @ home depot
SKU 0 39003 09131 9
holds like a .....
Do I need a new screw to go along with this bumper? Thanks a bunch, if this works I'm going to be so happy. Thanks
Old Apr 11, 2006 | 10:54 AM
god_of_cpu's Avatar
StreetDeck.com Developer
Your missing the metal plates on the magnet. It should of come with 2 metal pieces that direct the force of the magnet and touch the metal plate, without these, the magnet simply won't pull in the right direction.
Old Apr 11, 2006 | 11:27 AM
amthar's Avatar
How should these be oriented/installed? The directions make no mention of this nor do any of the pictures
Old Apr 11, 2006 | 02:41 PM
dovla's Avatar
Old Apr 11, 2006 | 03:07 PM
amthar's Avatar
Yeah, I saw that picture yesterday. I tried enlarging it, printing it, but it's a horrible picture. I *guess* the magnet is sandwhiched between the two pieces of metal? With the "extra" bit of the metal pieces facing the "top" side of the screen? When the directions make no mention of the metal pieces you would think that the abnormality on the top edge of the magnet is just that, an abnormality, and not actually the metal pieces sandwhiching the magnet and the magnet being slightly shorter. . .
Old Apr 11, 2006 | 07:14 PM
amthar's Avatar
welp, that did it. whew, HUGE weight off my shoulders. I'll post pictures in my install thread shortly.
Old Apr 11, 2006 | 08:20 PM
Gmachine's Avatar
I have the magnet with the two pieces of metal on it attached to my screen but it doesn't hold that well. Like if I hit the gas hard it will come lose. Which hole do you recommend screwing the magnet into? Is there anything else I can try?
Old Apr 12, 2006 | 12:07 AM
rcdash's Avatar
The magnet will hold very strongly if it is at the right height.
I also initially had this problem. I flipped the magnet 180 degrees and it sat up a little higher, but not quite 100% solid.
So I moved the magnet up a little by extending the screw hole "up" with a dremel to make this completely adjustable.
Chuck - you might want to consider a vertical "slot" rather than just a screw hole so that there is some room to play after the install.
Thebaws11
Jul 2, 2021 11:36 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
wuzz-upp
Oct 3, 2015 04:21 PM
mattdg35
Sep 14, 2015 11:28 AM
Jnm07
Sep 5, 2015 01:16 AM
