Alternative to Claybar?
Clay is plenty safe. The key point to not screwing it up is:
Before you start using, break it half and use half at a time. If you drop it on the ground, toss it and use the other half.
Knead the clay often
You should follow up with a polish.
In regards to an alternative, you may want to check out the AUTOPIA.ORG site. I think Adams or FK makes a chemical (2-3 step process I believe) that supposedly works pretty well!
Clay is relatively safe if you use plenty of clay lube, knead the clay frequently, use a clean piece of clay and thoroughly clean the vehicle before using the clay. There is a lot of good info on How To use clay bar at this link.
Originally Posted by RCMCFE
Is there a good SAFE alternative product for Claybar? I don't want to take any chances...
Thanks in advance...
No paint cleaner is a sufficient substitute for claying. Claying removes the contaminants stuck in the surface of the paint. It does this by grabbing and pulling them out as you pass over the surface. Chemical cleaners cannot do this. I have clayed many cars. It is simple. Just make sure you follow the directions listed by others above. Also make sure that you use plenty of quick detailer or clay lube. If the clay is easily sliding with no sticking, you are good to go as far as amount of lube. Use no pressure on the clay. Just let it glide over the surface of the paint as you work it back and forth. It is really simple to use and you can FEEL the difference between clayed and unclayed paint immediately. It makes polishing and waxing easier too. You should clay at least once a year.
i dont understand how u can screw up with claybars ...
just avoid the temptation to toss the bar into a pit of sand and then immediately using it on ur car.
Hell, it's just as unsafe as dropping your wash mit/applicator on the ground and using it again on the paint.
I've used Mother's Clay and it comes with a bottle of detailer spray (Showstopper I think). Like everyone else said, just spray on the car and a bit on the half bar of clay (make sure you are not doing this in the sun as the spray will dry faster) and gently rub back and forth. You can hear it working: it sorta sounds like you are pulling tape off of your car. I usually do this motion in about 6 inches of the car and for about 20 seconds or so (depending how dirty the car is). Once you are done on that spot, spray a little more on that spot and wipe off. That's it. Very easy.
brianuc4
19
Apr 10, 2020 02:12 PM
Thebaws11
Nov 30, 2016 12:54 PM
BradMD_96
Oct 6, 2015 09:31 AM
