debadging went bad. =(
Old Feb 26, 2007 | 07:52 AM
jiminy4DR6MT's Avatar
Yesterday I decided to debadge the "I N F I N I T I" letters, which went well and i kept the G35 badge on the car. but later i just decided to rush before the sun went down and i couldn't find any microfiber cloths so i used a paper towel looks like it left tiny microscopic scratches everywhere around the "G35" and it is still visible after a coat of wax last night. here's some pics:
What do I do now???
Old Feb 26, 2007 | 07:54 AM
Og_Dave's Avatar
best way to get that out is use a buffing machine, it will get those scratches right off after afew applications
Old Feb 26, 2007 | 08:29 AM
G35Dreamz's Avatar
If theres any consolation, I messed up on my debadging as well. Mine was worse than yours. Since it was an 03.5, the glue was stuck on pretty good. I had to resort to using a razor blade(big no-no). I had to rub it off with goo-gone and it made matters worse. I used touch up paint to cover it up. It's not a pretty sight. Now i have to find a body shop to fix what supposed to be an easy job.
Old Feb 26, 2007 | 09:24 AM
YoungGblood's Avatar
my friend had this problem, he went to auto zone and got something like scratch doctor and it fixed it w/o a problem, the paint and clear coat look brand new, you should try if the scratches aren't deep Ill gurantee it'll work. 10 bucks and its fixed, plus u have the bottle for any other minor scratches you have.
Old Feb 26, 2007 | 09:59 AM
i already tried goo-gone and a fresh coat of turtle wax. i think i'll try the scratch doctor product you mentioned at autozone. thanks guys
Old Feb 26, 2007 | 10:09 AM
Diesel1's Avatar
Moderator
Mequires SCRATCH X by hand if you do not have an orbital and polishes. It should work if you go over it 3-4 times.
Old Feb 26, 2007 | 10:10 AM
filanj's Avatar
goof off will work as well, or polish
Old Feb 26, 2007 | 11:14 AM
jameyb's Avatar
+1. Try some Scratch X first.
Old Feb 26, 2007 | 11:18 AM
Hi-TechG35's Avatar
I had the same problem but I washed the car and waxed the car. After the wax I took an orbital polisher with some Mugeuires Tech Wax and polished the trunk lid for 45 minutes. It looked like the logo was never there.
Old Feb 26, 2007 | 11:27 AM
LazerRed1's Avatar
Not familiar with ScratchX but had the same problem. You may need to use rubbing compound, then polishing compound, then the wax. Might try polishing compound first.
General rule is to use as least abrasive as possible to get job done. If that product doesn't work, go to a little more cut.
Don't do in circle. Go side to side if you do it by hand.
Old Feb 26, 2007 | 12:07 PM
Neal376's Avatar
+1
when I de-badge, i remove badges via heat gun, than I rub out the adhesive w/ light polish.
dun use rubbing compound -- way to aggressive. just a light polish and some (ok...alot of) rubbing will be just fine. keep polishing until it goes away...lol only use the rubbing compound if polish has no effect after like an hour of polishing . megs scratch X is really nice, it will become your best friend. strong enough to work in by hand, but not enough to dull the paint or cause any further scratches.
Old Feb 26, 2007 | 12:27 PM
When, I removed my "INFINITI" i used a hair dryer for a minute on each letter pulled it back a little bit with my fingernail and pulled if off CAREFULLY with a double edged blade w/o touching the car, w/e residue was left from the 3m tape I pushed off with my finger and it worked fine w/o scratches.
But anyway scratch x is same as scratch doctor. Same difference
Old Feb 26, 2007 | 01:03 PM
RocketG35's Avatar
Why do I bother to DIY???
+10 for the Meguiar's SCRATCH X. That will work miracles - scratches you think are permanent...will miraculously disappear. Give it a shot.
Old Feb 26, 2007 | 01:11 PM
ttrank's Avatar
Grocery getter
Scratch X or Zaino scratch remover. I used Zaino on mine and it took most of them off and gets a little better with each coat.
Old Feb 26, 2007 | 04:41 PM
wow all these solutions, i picked up mequires scratch X from wallgreens so we'll see how that goes. thanks again.
