Removing Embelems
stuck on w/ adhesive.. blow hair dryer for a few minutes, peel of with a credit card wrapped in cloth.. go slow and easy.. i believe 3M makes an adhesive remover for the excess crap.. gl
I wanted to remove the infiniti and g35 from my car but my only concern is I have an 04 in DG do you guys thing there will be some discoloration to the point where you can still see the markings after its removed?
Originally Posted by damafuka
Hot water and dental floss!
After that, good wash followed by polishing and wax should make your car brand new like
The letters are stuck on, like the others said 3M adhesive remover, hair dryer and patience. But for the Infiniti logo itself is in "screwed" in, for a lack of words, to the trunk.
then after you can do a dance, lol
I took mine off and after a few washes and waxes it looks all the same. I heated my letters up with the heat gun and used some dental floss and watched the letters drop to the ground.
Most asked question............!
Thanks for the heads up guys, I will remove my lettering when I get motivated one of these days
out the correct process......most of what I've read in this post is incorrect
or useless and might even cause damage to your lid!
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
FS[NorWest]: 04 OEM Faceplate and CD/Tape Unit
Oregon13
Audio/Video/Electronics
Mar 1, 2016 12:06 AM
