A Great Guide to Washing your Car!!
Old Jun 13, 2007 | 05:42 PM
krazzyguju's Avatar
Heres a step by step process of how to take care of your car! Ive found these steps and products to work really well.
I got this writeup from another forum that i visit frequently.
The Optimum No Rinse Wash and Shine is a great product! And yes you dont have to rinse the car or anything!
Products you will need:
2 gallon capacity bucket
1 wash pad, I like to use chenille covered foam pads
4-5 16" x 16" microfiber towels
2-3 terry cloth or cotton towels
Wheel brush(s)
Tire protectant
Glass Cleaner
Optimum No Rinse Wash and Shine: http://www.ecocarcare.net/no-rinse-wash-shine.php
Optimum Car Wax: http://www.ecocarcare.net/car-wax.php
Steps:
1. Using a capful or approximately one half ounce of Optimum No Rinse (ONR), add it to one gallon of water in the bucket.
2. Clean your wheels, tires and fenderwells using the ONR mixture and your brushes, wipe dry with the terry cloth towels.
3. Dress the wheels and fenderwells with your tire dressing-and don't forget the fenderwells! Dirty fenderwells detract from an otherwise clean and shiny car!
The reason to do the wheels and fenderwells first is so when you apply the tire dressing, any overspray will be washed off the car during the washing step.
4. Empty out your bucket and refill with clean water, adding one half to one full ounce of ONR (less if relatively clean, more if really dirty).
5. Using a chenille covered foam pad or a wash mitt, wash one section of the car at a time and dry immediately using two microfiber towels, one for the first drying pass and making sure you leave a little moisture behind, use the other towel for a second drying pass. If you get the panel completely dry with the first towel, then don't go over it with the second towel because rubbing even a soft microfiber towel on dry paint can leave streaks.
Once you get the process down (it may take a couple washes to really nail it) you should be able to wash the body of your car in 20 minutes or less unless it is really filthy.
6. After washing open your doors, gas cap door and trunk or hatch and wipe down all the jambs.
7. Using Optimum Car Wax (OCW), spray onto a section at a time. Don't soak the panel, just a mist should do. Spread the wax over the panel, flip the towel and wipe to a haze free shine. If you can use a detail spray, you can use OCW, it is that easy. Depending on your area, wash habits, etc, you can expect 3-5 months durability. Honestly though, it is so easy to use you will probably use it every few washes. Shouldn't take more than 10 minutes to do the whole car. In fact, you can also apply it as you dry each section when washing with ONR to save even more time, or apply while washing and apply a second coat for even better protection with very little additional time spent.
8. Clean your glass inside and out.
Stand back and admire your shiny car! Take pics and post them on OT!
There are several vendors who carry Optimum products, the one I would recommend first is www.exceldetail.com because he is an OT member and I believe we should support each other, plus he ships very fast, has excellent customer service, is an all around nice guy and he also carries a fine selection of microfiber towels, the rest of the Optimum product line as well as Clearkote, Poorboys, 4 Star, Propel buffing pads, etc.
Another excellent vendor is www.pakshak.com or the www.ecocarcare.net site, autogeek, etc.
Old Jun 13, 2007 | 06:08 PM
max2k1's Avatar
I've not heard of this product before -- good to know
Post some pics of the results .... how does this compare to say something like Zaino ??
But the process sounds a lot easier than Zaino
Old Jun 13, 2007 | 06:24 PM
krazzyguju's Avatar
The write up is actually from a professional that does this for a living and if anyone is familiar with forums.offtopic.com then you know who Scottwax is and you've seen his work. But here are a few cars he has done using some of this stuff.
Old Jun 13, 2007 | 06:37 PM
Lucky_One's Avatar
damn those cars are CLEAN....but that couldnt be just from one coat of wax, is it? i live in philly, it often rains here, how would u compare it to meguiars or mothers, 1-10, 10 highest.
Old Jun 13, 2007 | 06:42 PM
krazzyguju's Avatar
well thats from a few things apart from whats listed i believe but everyone ive talked to have said that these products work really well. That guy uses those products to start off all his washes. He does all high end cars such as Bentleys and Rolls Royces.
Ive never used Maguiars or Zainos so i cant comment.
Old Jun 13, 2007 | 08:28 PM
redlude97's Avatar
its better to have an additional 5 gallon bucket with a grit guard in it to drop your mitts into while drying. this will allow the grit to settle out and not get into the wash solution. I use ONR for 90% of my washes since I live in an apartment with a garage that doesn't have water access.
Old Jun 13, 2007 | 11:40 PM
sfgr415's Avatar
interesting
Old Jun 14, 2007 | 12:48 PM
Detailed Image's Avatar
ONR is a great waterless wash product. It definitely is a must for people like redlude97 who do not have easily accessible water access.
Old Jul 1, 2007 | 03:55 PM
vtb11's Avatar
just finished my first major detailing of my new car.. optimum is a great product! only complaint is that the spray wax is definitely hard with any breeze will make it flow onto random parts of the car and the heat on the car bc it dries extremely fast! once i got the hang of it, i was able to apply the wax easier
so, definitely do this in a garage or in the shade w/ no wind, which is probably a "duh" for many of you..
Old Jul 1, 2007 | 11:15 PM
a504boi's Avatar
^^ i see u! lol
newg37
Jul 26, 2015 09:32 AM
ClwMike
Jul 23, 2015 12:55 PM
Thunderaan
Jul 22, 2015 07:40 PM
kenthung
Jul 21, 2015 05:56 AM
Nog89
Jul 21, 2015 03:02 AM
