Clay Bar ADVICE
Old Aug 16, 2007 | 02:55 PM
MixturePinoy's Avatar
don't eat the claybar. yellow poo sucks
Old Aug 16, 2007 | 03:20 PM
O HELLA JDM's Avatar
HAHA HELLA RANDOM
but thanks all..will do and show pics of 2 cars im doing
Old Aug 22, 2007 | 02:39 AM
G-unit-SP's Avatar
I was told that claying the car would remove all bonded surface contaminants,
including the wax. Is it necessary to use dawn/IPA to remove the wax first.
I use M21 on my black G, wasn't sure if a sealant would behave any different from a wax.
Old Aug 22, 2007 | 02:45 AM
redlude97's Avatar
claying will always remove to some extent the wax/sealant on the paint due to the nature of a claybar. The aggressiveness of the claybar usually determine this though, and most OTC claybars are fairly gentle so only some of the wax will be stripped. Its stil a good idead to rewax after claying though
Old Aug 23, 2007 | 02:29 AM
damn it took me 4 hours to clay the whole car..still havent waxed it yet...should i also use spray detailer after i wax it??? just wondering or am i going overboard
Old Aug 23, 2007 | 02:54 AM
redlude97's Avatar
I usually use a spritz or two of QD to aid in the removal of the hazed wax and add a little pop to the finish. Then I follow up with a good spray wax for some boosted protection such as duragloss aquawax
Old Aug 23, 2007 | 02:56 AM
Queenskid24's Avatar
I know everyone mustve told you this already but make sure you use ALOT of paint lubricant. If yoou feel the slightest rough pass on the paint spray away with the lube, a couple of sprays on the clay itself also. Make sure to knead the clay after every panel.
Old Aug 23, 2007 | 06:51 AM
35bills's Avatar
As mentioned before, check out youtube for some video aid...
Old Aug 23, 2007 | 10:38 AM
yup...i check some out too but did it really quick...but i think i did a good job... made sure to keep it wet and i knead the clay after every pannel
Old Aug 25, 2007 | 07:01 AM
TOGWT's Avatar
I don't think stripping wax is all that important, most LSP's will redisolve old wax/sealant because of the solvents in them already, especially if you are using the same products. I only strip wax on cars I haven't detailed before or use 50/50 IPA/Water for removing polishing residue.
I usually 'clean' the surface (1:1 IPA or Menzerna Final Inspection) to remove oil/wax/etc to enable me to clearly see the surface marring without the benefit of 'fillers', and it also avoids a foam pad from becoming 'gummed-up' (is that a word?)
Old Aug 25, 2007 | 05:47 PM
darnelled's Avatar
4 hours!?? It usually takes me about 15-30 minutes to claybar depending on how long it's been since the last job. Check this how-to
http://meguiarsonline.com/forums/thread/5478.aspx
Old Aug 25, 2007 | 05:48 PM
darnelled's Avatar
Originally Posted by JOKER
how do you know if the wax is washed off?
http://archive.meguiarsonline.com/fo...ead.php?t=6825
Old Aug 25, 2007 | 06:20 PM
gary c's Avatar
Subject: Claybar Advice......!
Using a claybar is real easy, and the secret to doing the job well is to use
plenty of lube where your using the bar. If you're doing the hood spray the
lube on heavy then follow the body lines with the bar. Run your hand across
the surface to make sure the surface gunk is gone. For all you members that
insist on washing your car with detergent, you are drying out the paint!
And to be blunt that's stupid! There's not a professional detail person on the
planet that washes his cars with forking detergent, dawn or otherwise! I've
never washed my cars with anything but cold water and always in the shade.
Old Aug 27, 2007 | 02:21 AM
^^^ yup i used alot of the spray detailer...as long as its slippery i dont think you can mess up right ^_^
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
