Paint will fade if you buff to much
Old Apr 7, 2008 | 01:45 PM
lov3rboy408's Avatar
Cool Paint will fade if you buff to much
every month i buffer my car so it's had the clean look.. 12 times a year.. if i do this to much will my paint fade???
Old Apr 7, 2008 | 01:57 PM
redlude97's Avatar
What are you buffing with?
Old Apr 7, 2008 | 04:47 PM
i used meguiar X and after that i use the meguiar wax
Old Apr 7, 2008 | 04:55 PM
redlude97's Avatar
i don't understand, how are you buffing?
Old Apr 7, 2008 | 05:00 PM
superchargedg's Avatar
If you are using a pc,flex or rotary and medium to aggressive polishes dont expect to have much in the way of any clearcoat left but the paint wont fade.............................................. ....yet.
Old Apr 7, 2008 | 05:13 PM
speedracerg35's Avatar
12 times a year is excessive. you will eventually buff through the clearcoat. buffing twice a year is usually standard. try a claybar. it will give you the effect you want and not remove the paint.
Old Apr 7, 2008 | 05:33 PM
i used the PC to buff.. mostly i put number 3 , 4 to do it.. at first i apply Megiuar X .. and after that i put wax.. the car turn out smooth and shiny clean!! but i scare i will fade the paint day by day!
Old Apr 7, 2008 | 06:32 PM
redlude97's Avatar
What is meg's X? I assume you are referring to scratch-x? Its a pretty mild polish meant to be used by hand. At only speed 3/4 I doubt you are really doing more than polishing off a very thin layer.
Old Apr 7, 2008 | 10:16 PM
Scrooge's Avatar
Your paint won't fade. Cause are paints are not single stage paint. On single stage paint you'll see the paint fade (Oxidize). On Clear coat cars you won't ever see them fade.
Old Apr 7, 2008 | 10:17 PM
Scrooge's Avatar
Also what are you talking about, meguiars has alot of product that end with X.
Color X
Scratch X
Plastic X
Old Apr 7, 2008 | 11:25 PM
TurK's Avatar
You n00b....buffing more then like once every 6-8 months does not do anything....main purpose to buff is to get the paint applicable for wax/polish....
If your paint if smooth there is no need to buff it....try a claybar like they stated above....
Buff if you must to get scratches out....
Old Apr 7, 2008 | 11:26 PM
scratch X of cuz.. and wax
Picture Share
Feb 4, 2018 12:41 PM
DRG35R
Jan 31, 2016 07:14 AM
9tray turbo
Sep 29, 2015 10:22 PM
