Instructions for Clear Corners?
Re: Instructions for Clear Corners?
I just recently installed the clear corners as well.....
if you look in your owners manual, there is a section that covers light bulb replacement for the corner marker.....
If you take a small flat head screwdriver, wrap in in a pc of cloth or towel...insert it on the fender lip side of the marker between the corner marker and the fender and gently lift it outward. It should easily pop out and then you pull the assembly towards the wheel well and it will lift right out.
twist off the bulb socket maybe half a turn, and the bulb assembly will come right off the corner marker....
install the socket/bulb assembly on the clear corner and reinstall the same way you removed it.....Good luck!!!!!!
<font color=blue>2old4this</font color=blue>
04 cpe IP/willow/5at/prem/18's/JDM clear corners/Piaa's/MTEC H4 Super White fog/highs
wrah... haterrrrrrr. [img]/w3timages/icons/tongue.gif[/img] j/k.
(s)he probably just wants to make sure (s)he's doing it right so that (s)he doesn't mess up, break, or crack his/her $50+ mod. remember, we were all newbies once...
<font color=purple>.g35girl.</font color=purple>
As far as being easy to steal.......
I was considering Ducatiguys mod for the corners.....He put a metal rod thru the corner from the inside.....so nobody could just walk by and lift them.....
But I was a little afraid that they may do extra damage to the fender opening if they can't get them out too easily....
Either way your screwed.....I think if they want to get them they will.....So far I've had no problems....
But every time I walk out to my car after work I'm expecting to see my lights hanging there all alone!
Dennis
Dennis
I thought the bulb thing was mainly directed towards the higher temp/HID bulbs, not the 5watt in the corners......
when I changed out my fog/high bulbs, I was sure not to touch the glass of the bulb....
I did not see anything warning the same on the smaller bulbs.... I could be wrong...won't be the first time thats for sure...
I was just being an @ss, but I'm WRAH.....[img]/w3timages/icons/tongue.gif[/img]
...in the mean time, where is my steak woman? I never got it!!
...oh and "he" is synonymous with any sex, so their is no need to say (s)he!!! You Feminazi![img]/w3timages/icons/tongue.gif[/img][img]/w3timages/icons/tongue.gif[/img][img]/w3timages/icons/tongue.gif[/img]
"What if there is no tomorrow....There wasn't one today!!!" Bill Murray
'04 OB/GL Prem.Pkg./Sport.Pkg/Splash<P ID="edit"><FONT class="small"><EM>Edited by WRAH on 04/13/04 05:38 PM.</EM></FONT></P>
mizzoutiger... thanks for the tip!
gr8tg35... i remember some old threads where they used epoxy or plastic ties to keep the clears in, too.
wrah... no feminaziism involved. the only way that "he" can be synonymous with any sex is if you're a hermaphrodite. but don't you worry. either your little junior will grow some more or he'll just involute. [img]/w3timages/icons/wink.gif[/img]
.....but "he" is synonymous with any sex...... look it up!
"Used to refer to a person whose gender is unspecified or unknown: “He who desires but acts not, breeds pestilence"
~websters, and dictionary.com
'04 OB/GL Prem.Pkg./Sport.Pkg/Splash<P ID="edit"><FONT class="small"><EM>Edited by WRAH on 04/13/04 09:00 PM.</EM></FONT></P>
