Pine sap
Old Oct 28, 2008 | 07:58 AM
Infinitude's Avatar
Pine sap
Anyone know of a good way to remove hardened pine sap from the paint? I have tried several commercial bug and tar removers. They don't seem to work with sap. I even tried mineral spirits with no luck. I'm scared to try anything stronger (i.e. acetone).
Old Oct 28, 2008 | 08:01 AM
1180G35black's Avatar
I had some on my car this last wash I hit it with some goo gone then the clay bar and off it went. I hope this helps.
Old Oct 28, 2008 | 08:08 AM
tg1234's Avatar
Big no for acetone. You can screw your paint.
Claybar is your best option as it was mentioned by 1180g35black.
tg
Old Oct 28, 2008 | 11:10 AM
johnnyzee's Avatar
^+3
bug/tar remover then claybar.
Old Oct 28, 2008 | 01:38 PM
TheTick's Avatar
Claybar
Old Oct 28, 2008 | 04:03 PM
ugaexploder's Avatar
goo gone
Old Oct 29, 2008 | 08:20 AM
snowcrossmxz's Avatar
bug spray, like off
the deet will cut the sap, and not touch the clear coat
then just wash with soap after to remove the actual bug spray
Old Oct 29, 2008 | 10:52 AM
Detailed Image's Avatar
I'll typically soak a corner of a microfiber towel in Isopropyl Alcohol and let it sit on the sap for a minute or two, then I usually try to pick the top of the sap off with my fingernail, avoiding touching the paint of course. If it's difficult to remove, sometimes I'll add some degreaser to the alcohol mixture. Afterwards, I'll clay, then polish to remove any etchings that may have happened.
George
Old Oct 29, 2008 | 11:10 AM
gary c's Avatar
Here's another head up, if you had a good coat of wax on your car the pine
sap would have washed off. Quality wax every 90 days will eliminate the
need for concern about what you might get on your painted surface.
Gary
Old Oct 29, 2008 | 11:27 AM
im telling you, bug spray. no picking or scratching required
Old Oct 29, 2008 | 07:52 PM
cdmorenot's Avatar
as funny as it may sound..... WD40. it works like magic. a coat of wax right after and voila
rsingerG35
Accessories
Mar 16, 2016 01:41 PM
DannoG35
Sep 19, 2006 04:46 PM
lightforce18
Aug 25, 2005 03:53 PM
nyckid
Oct 25, 2003 10:59 PM
