Rain-X Fast Wax - Okay to use as Clay Bar Lubricant?
Old Nov 20, 2008 | 01:21 PM
Swivel's Avatar
Moderator
I *think* it's just a quick detailer. Anybody use it for claying? Reason I ask is it's on clearance for $3/bottle and I think I'll pick some up for claying.
http://www.rainx.com/Products/Waxes/Fast_Wax.aspx
Old Nov 20, 2008 | 01:24 PM
Jeff92se's Avatar
Red Card Crew
If it's slippery it should work. I've used plain water before. (or was it slightly soapy water?)
Old Nov 20, 2008 | 01:28 PM
richie's Avatar
hmmmmm, I have used Fast Wax before, and its white + thick.... I don't think it would make a good clay lube since it is pretty thick and won't keep the clay/surface wet. Im sure it'll work, but I think quick detailers/waxes that are more water based would work better.
Where is it on clearance for $3??? I want to pick some up.
Old Nov 20, 2008 | 01:30 PM
Swivel's Avatar
Moderator
Fuggedaboutit richie, I saw it first!! haha! Local Safeway store, might not be worth the trip from LA to Calgary, Canada to pick it up.
Old Nov 20, 2008 | 02:11 PM
redlude97's Avatar
ONR diluted to claybar strength is WAY cheaper than $3/bottle. Or bulk Meg's Last Touch Detailer diluted to claybar strength is another great option.
Old Nov 20, 2008 | 02:51 PM
Ghaleon0721's Avatar
The answer is categorically NO.
Claybar needs a lubricant. This stuff may "feel" like it's slippery, but that's because it's applying a coat of wax on your car.
Simply put
Clay = take stuff OFF your paint
Fastwax = put stuff ON your paint.
Completely incompatible.
For the money, you really can't beat Mother's claybar IMO. It's usually like $16 - $18 and you get the clay, AND the lube.
How much claying do you plan to do anyway? If your claying enough that you care about a small discount on lube, you're probably doing it too often. either that or you're not adding adequate protection (wax/sealant) to your car after you clay so it gets dirty again.
The mother's kit is enough to do a car twice. I wouldn't recommend claying more than once or twice a year anyway.
Old Nov 20, 2008 | 03:20 PM
Solekeeper's Avatar
I usually just use soap water.
Old Nov 20, 2008 | 03:46 PM
What kind of soap. I'm sure it works great as a lube, but I would be worried about streaks and residue.
Quick Detailers are formulated so that they provide some lubricity, but won't leave a residue like regular soap.
I suppose if you wash the car right afterwards (which alot of people do after claying anyway), you would be fine.
Old Nov 20, 2008 | 04:05 PM
Swivel's Avatar
Moderator
I have the Mother's kit, but nearly out of detailer. Diluted ONR, didn't know that one, thanks RL. Won't be claying again til spring, so I have time to consider. Thanks all.
Old Nov 29, 2008 | 04:48 AM
in2win's Avatar
small spray bottle, decent amount of car wash soap and water...it will slick as hell. You should be washing between claying and waxing anyway so it doesnt hurt.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
dcsbh1
Oct 1, 2015 03:15 PM
