What clay and lube you using?
Old Feb 22, 2009 | 09:49 PM
1180G35black's Avatar
in for the best
Old Feb 23, 2009 | 02:32 PM
crazeejitt's Avatar
Originally Posted by solopresident
i use meguiars and love it! tried mothers didn't like it as much. it left clay on the paint.
how exactly did you get that clay residue off the paint all the way?
Old Feb 24, 2009 | 02:02 AM
Lucky-G's Avatar
rub, rub, and rub some more. If there's clay left on the paint usually that means one of a few things: The clay was too hot (paint was too hot), you didn't use enough lube, your clay bar is done-for, or you bought a junk clay bar to begin with.
Old Feb 24, 2009 | 03:00 AM
Spec R's Avatar
yep, its more important that whatever lube you're using is "approved" for the clay that you're using.
if not, the clay will either not lift the contaminants as efficiently (too slick of a lube = more passes with clay = more potential for marring), or the clay will stick to the paint (more marring)
i personally use Prima Glide with Meguiars Blue (Mild) clay, or Red (aggresive) clay.
Old Feb 24, 2009 | 03:13 AM
Lucky-G's Avatar
What in God's name are you doing with an agressive clay on a 2006?!
Old Feb 24, 2009 | 06:16 AM
Spec R's Avatar
haha i was talking about cars in the past i've only used mild on the g35.
but yes, any aggressive clay bars will leave marring that will need machine polishing. however,once polished, it comes out supppperrr slick
Old Feb 24, 2009 | 10:25 PM
Jay.Diem's Avatar
yep a PC or Flex will lift those light swirls out pretty easy .... if the paint has never been clayed before and the car is more than 2 years old, i'd go red clay as well
Old Feb 25, 2009 | 12:40 AM
Lucky-G's Avatar
My ***** aren't big enough to use a PC on my baby...I'm afraid to hurt her!!
cmesidewayz
Sep 29, 2015 09:28 PM
Mattdi
Sep 28, 2015 08:34 AM
Mattdi
Aug 23, 2015 11:27 PM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
