Debadging My Way
Old Jul 19, 2004 | 03:54 AM
GeeCoupe's Avatar
Debadging My Way
Check it out I used the Goo Gone Citrus like some other people do, but I blasted the word " I N F I N I T I" off with my power washer!!! The words came off like nothing!!! The "G35" Badge is a little bit tighter but was very loosened so I pulled off with my hand so easily; the "Mt. Fuji" which is stiffer came off w goo gone and a flathead(becareful) I put some goo gone on the left over residue... let it sit and buffed/blasted it away with power washer......
Old Jul 19, 2004 | 06:33 PM
Raznips's Avatar
Re: Debadging My Way
wow... thats incredibly bad for your paint.... i knew a guy who started washing his wifes car with a power washer thinking it was a good idea and the paint on the hood started peeling off in the middle of it... that was a bmw.. i cant even IMAGINE wth a g35's horrible paint
2004 Black on Black g coupe 6spd.... aluminum pedals, clear corners, z tube, and pop charger. soon to have 19" volk gt-c's and PIAA xtreme whites in the clearance and corners
Houston Texas
Old Jul 20, 2004 | 02:29 AM
GeeCoupe's Avatar
Your'e right; howerver there are different modes on the power washer ofcourse that way was the direct stream, basically a straight beam of water like a laser, I dont use that to wash my car...I regularly wash my car with the power washer, I set it to fan out( like a v) it's less pressure but enough to get the dirt off the bottom of the car, I use only straight beam high pressure on the wheels occasionaly
Old Jul 20, 2004 | 09:28 PM
g35david's Avatar
The easiest way I found was to use some dental floss. Just slide the floss between the emblem and the car in a side to side motion and the the emblems come off with ease. After that I used some rubbing alcohol to remove the excess "sticky" tape. Then detailed the area with some polish. Look great, and easy to do.
'04 diamond graphite, 6MT
<P ID="edit"><FONT class="small"><EM>Edited by g35david on 07/20/04 06:30 PM.</EM></FONT></P>
Old Jul 21, 2004 | 03:14 AM
skeleton_cru's Avatar
Sedan
Same way I did mine, but I used Goo Gone for the left over sticky residue.
Old Jul 22, 2004 | 12:13 AM
TCFOOL's Avatar
I pulled that corporate carp off and used my PC and buffed any remnats off and it looks great......
TC
"There is a Very Fine Line Between "Hobby and Mental Illness"
Old Jul 22, 2004 | 05:22 PM
OvaYahead's Avatar
instead of rubbing alcohol I just used car polish to remove the rest. It get's the junk off plus still good for the paint.
Old Aug 28, 2004 | 10:34 PM
takuyaah's Avatar
i am so sorry to go off topic...but i decided to put the emblems back on....does anyone know what kinda tape i should use and where i can get them? please help =)
Old Aug 29, 2004 | 01:03 AM
Aznteazer's Avatar
how are you going to align all those letters?
i duno about the tapes, but u shud just try to get rid of the scratches best u can and put the new emblems on (SKYLINE) over the scratches even if theres little scratches visible.
Old Aug 29, 2004 | 06:09 AM
takuyaah's Avatar
i think i kinda got rid of the scratch.....i tinted (sprayed) some of my emblem..i am wondering how to put it back on....
need to know where and what kinda type i should get ....please? =) i researched on this board and found "double sided foam tape" what is that and where can i find it? what brand? =)
Old Aug 29, 2004 | 11:12 AM
FrostHeave's Avatar
You want to find 3M™ Automotive Attachment Tape. Ask at PepBoys or Autozone. See this for more info:
http://products3.3m.com/catalog/us/e...er/output_html
2004 G35 6MTs Diamond Graphite/Graphite
New Hampshire
Old Aug 29, 2004 | 01:03 PM
takuyaah's Avatar
i love you =)
i need help however...i tried to heat up the infiniti emblem and stuff...and i used floss until i couldn't feel my fingers and it seems like it just doesn't wanna come out...
the other g35 and infiniti words are really easy...any more tips please????? =)
<P ID="edit"><FONT class="small"><EM>Edited by takuyaah on 08/29/04 02:55 PM.</EM></FONT></P>
zoop425
Mar 29, 2016 05:51 PM
zeero
Jul 3, 2006 12:33 AM
Gaaaar
Feb 12, 2005 04:50 PM
