Clear Coat Question???
Old Feb 7, 2010 | 08:17 PM
Reggae420's Avatar
I am painting my grill right now, I just finished sanding it down with 100 grit sand paper and now I just applied the second coat of " Krylon Fusion Plastic Paint" When I put the 4th coat on I am going to put 3-4 coats of clear coat. I went to Home Depot and got "BEHR Polyurethane Finish B-600 crystal clear satin" I looked on the back and it says that it is for "all interior bare or water base stained wood surfaces" but the guy told me that I could use this clear coat on the plastic grill. Is this gonna make my paint job peel? Please let me know.
Old Feb 7, 2010 | 08:26 PM
gary c's Avatar
Since you're using Krylon paint why wouldn't you use Krylon clear, I've never thought mixing company/formulas was a good idea....
Gary
Old Feb 7, 2010 | 08:33 PM
Reggae420's Avatar
They didn't have the Krylon clear coat, what should I do? Should I try this clear coat out? I'm pretty sure it'll be fine I just wanted to make sure.
Old Feb 7, 2010 | 08:39 PM
4DGS's Avatar
Don't use it.
Reggae420's Avatar
Would it just be better to go without clear coat the to try using this one??
Old Feb 7, 2010 | 08:51 PM
Devinb30's Avatar
go to autozone, pepboys, advanced autoparts. Get some duplicolor clearcoat. (if your doing this job with a spraycan).
Old Feb 7, 2010 | 08:58 PM
Reggae420's Avatar
I spray painted some plastic with the krlyon paint and waited for it to dry and then clear coated it with the behr and it was fine so I don't tihnk I'll have a problem
Old Mar 24, 2010 | 12:14 AM
djjg35's Avatar
paint it with a realy paint gun they come out much better
rsingerG35
Aug 18, 2015 10:16 AM
linedr89
Aug 17, 2015 05:11 PM
gatorglaze
Intake & Exhaust
Aug 17, 2015 02:16 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
