touhc-up paint gone bad
Old May 6, 2010 | 07:18 AM
jmcohen23's Avatar
So I lightly scratched my car (about 2 inches). I mistakenly thought to use my touch-up paint rather than scratch-X. the paint dried, and now looks worse.
is there a quick and easy way to fix this?
thanks!
Old May 6, 2010 | 12:20 PM
GR6RR's Avatar
razor blade...
Old May 6, 2010 | 12:27 PM
miltoda's Avatar
Prepsol dissolves most touch-up paint. It's a chemical most body shops have on hand. Not sure if you can buy it at a store.
Old May 6, 2010 | 02:31 PM
G2FLIP4's Avatar
everything
Originally Posted by sonny35
razor blade...
epic fail
Old May 6, 2010 | 05:30 PM
sexyrob's Avatar
not really epic...
Old May 6, 2010 | 05:46 PM
GR6RR's Avatar
really.. razor blades to remove paint drips... or what the OP is describing... sounds like paint drips..
Old May 6, 2010 | 05:49 PM
G2FLIP4's Avatar
everything
Originally Posted by sexyrob
not really epic...
Well in my book its an epic fail...
wetsand with 2000 grit then buff out the area.
Old May 6, 2010 | 05:55 PM
jibberjabbers's Avatar
Post some pics. And always try a rubbing compound first for surface scratches.
I would get masking tape and tape around the touch-up area.
Then wet sand the area in-between the masking tape.
After you get rid of most of it, you can probably just buff it out to blend it all back in.
Old May 6, 2010 | 08:31 PM
jmcohen23's Avatar
thanks for the help ya'll.
I used a sand-paper block (one of those soft ones from home depot), and buffed it out, then applied scratch-x.
I'll give her a good waxing this weekend.
Attached Thumbnails touhc-up paint gone bad-0506102019.jpg   touhc-up paint gone bad-0506102022.jpg
cmesidewayz
Sep 29, 2015 09:28 PM
n2fooz
Sep 4, 2015 07:46 PM
jbmw002
Sep 3, 2015 08:42 PM
