Removing Blue From Titanium Tips?
Old Jan 11, 2015 | 10:18 PM
digital sol's Avatar
I purchased a used HKS exhaust with titanium tips that have the burnt blue ends & I am currently polishing the entire exhaust back to an original shine. I would prefer to remove the blue from the tips entirely and just have them polished. Has anyone used blue job or blue away on titanium to remove the blue? I removed some but it took a ton of elbow grease and its still not entirely gone even in that small section. There has to be a better way or product to assist with this goal.
I have been using borla exhaust cleaner & polish & its worked great for everything else thus far. I have been using fine steel wool as well.
Thoughts?
Thanks fellas!
Old Jan 11, 2015 | 10:20 PM
Lartytiejdke3's Avatar
I accidentally hit a tiny little section of my burnt part with a dremel and mothers polish
Took it right off
You don't like the burnt tip look?
Old Jan 11, 2015 | 10:43 PM
Took it right off
Ok, ill give that a shot, thanks.
It looks ok but personally i just like the straight polished look, its simple and clean. I have to polish them anyways to get rid of some melted plastic on the tips but if i ever want the colored tips i just have to bust out the blow torch and have at it. Thanks!
Old Oct 25, 2022 | 05:31 PM
jbarnett250's Avatar
Saw some youtube video of a canadian girl that is a super welding expert. She shows how to make high end custom mototcycle exhausts out of titanium. She says industrial welding standards will reject welds if they're blue. Like it means something like you overheated the weld or something.
Old Oct 25, 2022 | 10:04 PM
MooseLucifer's Avatar
5 Year Member
blk
I used to work in a factory making Ti springs for aerospace. Out of the oven all Ti was blue/purple, caused by oxidation. The oxidized surface is brittle and will propagate cracks. Doesn't matter for an exhaust, but can cause failures in high load situations.
Old Oct 30, 2022 | 08:58 AM
That's so weird. I didn't realize I responded to an ancient thread. I only look at new posts so don't see how I dug that up...
Old Oct 30, 2022 | 12:53 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If you have infiniscroll turned on you will automatically scroll into another thread when you hit the final post on the thread you're reading.
Personally I find it annoying and turned it off make sure to click the SAVE CHANGES button at the bottom of the screen.
Old Oct 31, 2022 | 04:28 PM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
There was a new thread where someone polished the bluing off their newly acquired Motordyne cat-back. As Cleric suggests you probably infini-scrolled your way into this one from there.
Polishthrust
Oct 28, 2022 10:22 AM
digital sol
Jan 28, 2015 03:36 PM
Gatorbait
Nov 30, 2008 12:03 AM
_jb
Feb 18, 2007 07:54 PM
g6g35
Aug 11, 2005 02:04 AM
