Scratched Clear Coat
Gokart, you can use a polish and a lot of elbow grease to get that out. The best
way is with a DA polisher. It's safer than a rotary and much faster than by
hand. The next time you try to remove bird poop of your vehicle, wet a towel
throw it in the nuker for a couple of minutes so that it is hot and wet and lay
it on the spot for a couple of minutes. Then just spray it with a garden hose.
Comes out with no scrubbing and no damage. This is the prefered way to remove
bug splatter from a motorcycle helmet without scratching the clear lense
