pen on door
Old Jun 24, 2005 | 02:49 AM
crazybeckhams_G's Avatar
pen on door
does anyone know how to remove pen marks on the inner door handles(not the actual handle but the part you pull on to close the door. i've tried leather cleaner, windex, shout, even clorox. nothing seems to work.
Old Jun 25, 2005 | 12:54 AM
Ferrarimanic360's Avatar
maybe the magic eraser can do something!!!!!!!!
Old Jun 25, 2005 | 08:25 PM
Haven't tried the magic eraser yet but goo gone didn't even make a difference! I'm gonna try to post pics but don't know how
Old Jun 25, 2005 | 08:54 PM
fstedd's Avatar
nail polish remover should do it.
Old Jun 27, 2005 | 09:14 PM
obender66's Avatar
I don't think it is a good advice-it will eat your colour and plastic. Try rubbing alcohol in small area first-it may discolor the panel, but it won't damage plstic at least.
Old Jun 28, 2005 | 05:00 PM
Punchit's Avatar
What is the material on the area the pen has hit?
I think I have an answer for you but I just want to be sure what part you are talking about. Different materials can sometimes require very different cleaners.
p.s. be careful with the glass cleaner, their can be chemicals in there that can really damage leather and other parts of the car
Old Jun 29, 2005 | 03:48 PM
Thanks for the heads up on the nail polish remover.......... punchit: It's on both plastic and leather parts of the door handle. On the flat top part where the door handle meets the door panel.(the part you use to close the door when seated in the rear.)
Old Jun 29, 2005 | 05:05 PM
Punchit's Avatar
Gotcha thanks for the response.
One product should be able to clean both of them, I've gotten just about all stains out of vinyl, plastic, leather, etc with the 303 Aerospace Cleaner. This is an industrial strength cleaner that can and should be diluted. It's safe to use on the above mentioned surfaces and much more. I apply it with a microfiber towel and that usually takes care of it. If this doesn't work I can also recommend that use the Leatherique Prestine Clean to atleast treat the leather. There are two steps in the Leatherique process but you should only need this one to get it out. Leatherique is by far the best leather cleaner that I've ever used. If for some reason this doesn't help please let me know and hopefully I can help you. I have some other steps you can do but this should do it.
Old Jun 30, 2005 | 12:30 AM
Texan1's Avatar
Q50 Red Sport 400 RWD
http://www.thriftyfun.com/tf999996.tip.html
This person cleans banks and doctor's offices. "I have used anti-bacterial hand gel with great success. Rub it into the ink and go do something else leave on the ink for about 5-10min. rub off with soft cloth or whatever cleaner you normally use. I've also removed permanent marker from countertops with it, adhesives, and chewing gum from a carpet. It will also remove black shoe marks from tile floors, and scuff marks from walls. I now keep a bottle with me at all times and when you're done cleaning you can use it on your hands."
Here is another one about ink off leather: http://www.thriftyfun.com/tf508696.tip.html
just wanted to let you know that I have a 2003 Lexus with a crème color interior. The other day I found a red ball point pen mark across part of the front seat. Not sure how it got there but nevertheless I was upset.
Did not have any hairspray so I used the 70% Isopropyl alcohol solution and IT WORKED!!
Old Jun 30, 2005 | 01:20 PM
thanks for the link punchit. I'm going to try the hair spray thing as soon as I get my hands on some; if that don't work I will order the aerospace cleaner.
Dallsinghjr1
Sep 17, 2023 11:25 AM
RA081024
Interior
Oct 27, 2015 07:27 PM
toadfire
Sep 21, 2015 07:15 AM
douglas555
Sep 10, 2015 04:48 PM
jbmw002
Sep 3, 2015 08:42 PM
