Zaino Or Sonus W/ Klasse
Old Jan 4, 2006 | 05:50 PM
pdaplaya's Avatar
Does Anyone Use Sonus Detailing Products, Along With Klasse Aio/hg Sealant, From Autotopia.com? If So, What Are Your Opinions/comparisons To Zaino? Pics Please Especially Of Black Cars.
Old Jan 4, 2006 | 05:57 PM
neal540's Avatar
i saw a picture of klasse aio and the sealant glaze with a layer of p21s carnauba wax on top. wow it blew me away
Old Jan 4, 2006 | 06:06 PM
neal540's Avatar
https://g35driver.com/forums/showthr...highlight=p21s
bingo
Old Jan 4, 2006 | 06:18 PM
Picus's Avatar
Staff ALUMNI
Sonus is mostly polishes, the only comparable Zaino product is Z-PC. Since Sonus has three polishes the lineup has the advantage over Z-PC of being a little more fleshed out. In terms of sealants, Zaino is much more durable than Klasse SG, and much easier to remove after application - so if the only choice is klasse SG vs. zaino z2, I would pick the z2, but would do all my polishing with Sonus's polishes - that is if you need polishing at all.
For your sealant/wax you could use AIO (cleaner plus a weak sealant) and top it with a durable wax, as mentioned above. In that case I'd pick a wax like Clearkotes Carnuaba, Collinite 476, P21S, or Poorboys Nattys Blue - any of those should last 6-8 weeks. You could also just skip the sealant all together and go from polish to wax, or pick a different sealant all together.
Old Jan 4, 2006 | 09:28 PM
FrizzleFry's Avatar
completely agree. As far as sealants go SG is sometimes a bit difficult to work with. With waxes... collinite lasts pretty long but I'm starting not to like the beading. The beading on a dirty car tends to leave dirt circles all over... which is why I'm going back to FMJ for the winter/rain season since it sheets off well rather than bead. No more unsightly dirt circles for me.
Old Jan 4, 2006 | 10:14 PM
ballisticus's Avatar
This is what I was able to achieve with the old Z5/Z2 combo. But I have found equal results can be had with the Meguiars #80 followed by their NXT Tech wax. And its half the price and comes off WAY easier than the Zaino. Last just as long too. Im a Meguiars convert now.
Attached Thumbnails Zaino Or Sonus W/ Klasse-mirror3.jpg
Old Jan 4, 2006 | 11:51 PM
Picus's Avatar
Staff ALUMNI
Ya, as many times as we all say this it's true that the key is prep. Your sealant/wax combo will only look as good as the paint its protecting. Spend 90% of your time getting the paint marring-free and smooth and any of the products mentioned in this thread will look great.
Old Jan 5, 2006 | 01:58 AM
G35SHAWN's Avatar
Sonus poilsh is actually very good, i used it on my car before & i was very impressed...
Old Jan 5, 2006 | 08:13 AM
tkman00's Avatar
im not entirely familiar w/ sonus, but if it has oils, then u cant use it w/ zaino. you could probably use zaino after aio if you wanted. just use the klasse twins and call it a day
Old Jan 5, 2006 | 08:44 AM
Picus's Avatar
Staff ALUMNI
Sonus polishes are like any other - after you use them wipe down with rubbing alcohol/water and you'll be able to use any lsp.
Old Jan 5, 2006 | 09:52 AM
GR8TG35's Avatar
My experience with Klasse products have been very good. The first time I applied them, I definitely used way too much.....and it made removal more difficult than needed. I found that if there was too much build up, spray Sonus acyrilic spray, and it will easily remove any residue.
I find the P21S wax the easiest product I have ever applied and removed. It goes on like butter, and you do not need to wait for it to haze, just buff it right off.......I can usually do my entire car in under 30 minutes....the only sacrifice is its not long lasting, and you will find yourself applying another coat within 4 weeks.....
Between coats of P21S, I use the new Sonus Detailing Spray....I find it to work the best in long term performance, and I usually apply a coat after every wash. The attached pics show what the results are on a white car. I was quite impressed with the overall results.
Attached Thumbnails Zaino Or Sonus W/ Klasse-carpichoodshotrev.jpg   Zaino Or Sonus W/ Klasse-cprightsdrev.jpg   Zaino Or Sonus W/ Klasse-cpbackendrev.jpg   Zaino Or Sonus W/ Klasse-carpicrearsiderev.jpg   Zaino Or Sonus W/ Klasse-cptrunkrev.jpg
Old Jan 7, 2006 | 11:38 PM
grizzly's Avatar
Originally Posted by ballisticus
This is what I was able to achieve with the old Z5/Z2 combo...
comments on picture:
1) dude, paint the garage!
2) Mobile 1-- atta boy!
3) what's with the safe?! don't trust the bank? oh, on second thought that looks like a rifle/shotgun safe heh, um, nice ballisticus
alrighty then, a lot of good comments on this thread
  • Klasse All-In-One is advertised as a cleaner, polish, & wax
  • Zanio Z-2 is not a cleaner or a polish (this is 9 x out of 10 a good thing)
  • Zanio can be layered and lasts (comparitively) longer
  • Klasse AIO ~$20 for 10oz
  • Z-2 ~$15 for 8oz
in theory, you would be using Sonus before applying Z-2 if you needed to get rid of imperfections.
On the otherhand, Klasse AIO is supposed to take care of the imperfections and then you would use the "optional" Klasse High Gloss Sealant Glaze for the best results... This SG can be layered like Z-2.
i like Zaino, and have not tried Klasse.
Nikku-
Nov 27, 2009 11:26 AM
Triji
Apr 30, 2006 04:34 PM
TCFOOL
Mar 16, 2004 03:59 PM
bkchang79
Dec 20, 2003 11:50 PM
