Can you CG over Ziano??
Since ziano is great at removing swirl marks and shine... umm say if you put 5 coats of Ziano on and then just maintain with CG (since it is harder) and will prevent scratches and swirl marks? 1 thing iv noticed about Ziano is that it is VERY sensative.. If you rub you finger down the paint it will leave very light scratches..
Re: Can you CG over Ziano??
A chain is only as strong as its weakest link. The CG is actually formulated to bond to the paint's surface, not waxes, and since Zaino is so 'sensitive', it would make CG susceptible to coming off whenever the Zaino would have.
CG really needs to come up with a way to remove, not just prevent swirl marks. I'm sure there are people on this forum that will tell you the proper steps to take to remove them without adding a permanent compound. Good luck!
G
2003.5 Black w/ Willow G35
Premium / Sport / Aero / Winter / Navi / Tint
G
jackygor
Jan 16, 2007 11:03 PM
