wax help!! messed up
Old Apr 27, 2006 | 10:45 PM
nightrider's Avatar
i fvcked up while i was waxing my black car... there are white lines that u can see in the sunlight. I used the NXT meguairs wax.
IS the turtle ICE WAX good? i heard it doesnt leave any streaks or anything when u apply it on your car.
http://www.turtlewax.com/
Old Apr 27, 2006 | 10:48 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
wash it with dawn dish soap to remove the wax then start over. I've used NXT on my car for the past 9 months and never had a problem with it.
-GP-
Old Apr 28, 2006 | 12:36 AM
mr_ecktid's Avatar
Dish soap should be good enough to remove it.
How did you apply it?
Old Apr 28, 2006 | 02:36 AM
nightrider's Avatar
this was my first time waxing and I guess i didnt evenly apply the wax..
-so with dish washer soap i just wash the car like i normally do?
-with the nxt can i wax in a circular motion so i can even spread the wax with out makin swirls?
-how is the turtle ice wax? anyone try it?
thank you for the tips!
Old Apr 28, 2006 | 03:16 AM
g356spd06's Avatar
dish washer soap should take the wax off. dont do a circle motion. just slide the applicator at an angle so you can get the wax in the area you want. never tried turtle wax but i heard its not as good as nxt.
Old Apr 28, 2006 | 03:29 AM
redlude97's Avatar
likely if you are seeing white still, its not in the application, but the removal of product. It never hurts to apply too much product, it just means more wasted wax, and a harder time of removal, but it will still leave a uniform layer of wax. You say nothing about what method you are using to remove the wax, which is likely your probleem. I recommend purchasing a few decent microfiber towels to remove, and you shouldn't have any streaking left.
Tmatheso
Dec 13, 2015 03:24 PM
Learned Hand
Oct 1, 2015 09:02 AM
TNRocker
Sep 21, 2015 08:36 AM
bigmike
Sep 17, 2015 01:58 PM
