Stillen Intake install question...
Old May 23, 2008 | 05:07 PM
syshs's Avatar
I know, its a nooby question... but I need help asap...
https://g35driver.com/forums/showthr...65#post3045465
Old May 23, 2008 | 05:28 PM
SDGeneralCounsel's Avatar
read your installation instructions
Old May 23, 2008 | 05:44 PM
syshs's Avatar
I did! All it says is "fit" your Intake into that black plastic thingy.
But what then? It just says "fit it in there and then attach the M.A.S"
I'm guessing I just put the Metal clamp around the Intake and tighten it.
Then put it inside the black plastic thing and from the outside attach the M.A.S with its 4 screws.
But then what are the other 4 screws for??? Am I missing something?
Old May 23, 2008 | 06:53 PM
syshs's Avatar
So, I installed it (Stillen intake with Z-tube)... and took it for a drive... everything seems to be ok so far. Here are some pics... does that install look normal?
I was still left with 4 extra screws. I hope I did everything ok. I wonder what they were for...???...
Old May 23, 2008 | 07:05 PM
ricerocketdave's Avatar
Here are a few pics of mine..
Old May 24, 2008 | 01:38 AM
fishert16's Avatar
I just installed a z-tube/pop charger and I was left with four screw. I was confused then I realized it was from the four screws that connects the MAS housing to the new air filter bezel. I bet your new one came with four new screws as mine did and you were left with your four old ones? I hope this helps!
Old May 24, 2008 | 01:46 AM
speedracerg35's Avatar
don't forget to take off the foam piece off the stock box along with the two clips and mount it onto the opening of the stillen box.
Old May 24, 2008 | 05:06 AM
syshs's Avatar
Yes, it does help. I just used the old screws.
Those extra screws did confuse me.
Old May 24, 2008 | 05:07 AM
syshs's Avatar
Yes, I did that after taking the pics... I dont know if that really makes a difference or not though. Does it???
Old May 26, 2008 | 12:24 AM
KsuMax's Avatar
how much did it cost you?
RA081024
Aug 18, 2015 07:03 AM
linedr89
Aug 17, 2015 05:11 PM
RA102223
Aug 15, 2015 09:24 PM
Team STILLEN
Aug 10, 2015 08:17 PM
