Where in DFW should I go for ...?
Old Nov 7, 2011 | 04:36 PM
  #211
JaE35's Avatar
Moderator
G35 Sedan
Think i'll go with this sense my amp is 4 channels
http://www.sears.com/shc/s/p_10153_1...=SPM5836954901
Will stop by wallmart
Old Nov 7, 2011 | 04:43 PM
  #212
BlueBOB's Avatar
This is a higher quality product... I'm sure you can find a better price online if you look...
http://www.pac-audio.com/productDeta...&CategoryID=28
  #213
JaE35's Avatar
Moderator
G35 Sedan
looks fancy i like it
Old Nov 7, 2011 | 04:44 PM
  #214
JaE35's Avatar
Moderator
G35 Sedan
Do i need more cabling for 4 channels or will any amp kit work?
Old Nov 7, 2011 | 04:49 PM
  #215
BlueBOB's Avatar
Well, you have a 4 channel amp, but you're using that amp to power a sub?
Old Nov 7, 2011 | 05:26 PM
  #216
JaE35's Avatar
Moderator
G35 Sedan
two seperate subs, was gonna send two channels to each one
Old Nov 7, 2011 | 05:43 PM
  #217
BlueBOB's Avatar
I'm assuming you're bridging the 4 channels to 2 channels? If so, then no. Just the single pair of RCA's from the box to the amp, then all the necessary power wires. Not sure if the amp kit will have the wires to go from the amp to the sub.
Old Nov 7, 2011 | 06:10 PM
  #218
ungarocd's Avatar
Try this for an integration piece.....
http://www.audison.eu/index_main.php?Section=BITTENPROD
Sums the signal coming in, gives you 31 bands of EQ on each of the five channels out plus time correction. Sounds very nice. It works perfectly with the Hertz HDP5.
http://www.hertzaudiovideo.com/default_en.htm
Old Nov 7, 2011 | 06:20 PM
  #219
JaE35's Avatar
Moderator
G35 Sedan
Old Nov 7, 2011 | 06:27 PM
  #220
ungarocd's Avatar
Ah...just read back further into the thread. Looked like you were doing a full system upgrade. Not a bad way to go though eh?
Old Nov 7, 2011 | 07:06 PM
  #221
JaE35's Avatar
Moderator
G35 Sedan
not at all, those look pretty high end...is soundscape your company?
Old Nov 7, 2011 | 07:08 PM
  #222
ungarocd's Avatar
Yeah, it's my shop. We are small and specialized. The HDP5 actually retails less than the HD, and sounds better. Go figure.
Old Nov 7, 2011 | 07:25 PM
  #223
JaE35's Avatar
Moderator
G35 Sedan
good stuff, lot of great small businesses out your way
Old Nov 7, 2011 | 07:28 PM
  #224
ungarocd's Avatar
Well look out, we are scoping out a new location in Plano!
Old Nov 7, 2011 | 07:29 PM
  #225
JaE35's Avatar
Moderator
G35 Sedan
good, get out here and hook my stuff up
