Gears!
Gears!
I was wondering since i dont know too much about cars why is it that once i go to about 20-30mph it is soo hard to down shift to 1st gear some ppl tell me that on there cars its smooth the whole way through is there something wrong with my tran or is that the same with all ur g's(i have a 2003 6mt). The gears arnt as smooth as i want them to be but overall i love my car. plz give me the info thanks
You really don't want to do that too often since it will eventually prematurely wear out your 1st gear synchro ring (unless you do it perfectly every time)...
C.
There is no reason to downshift into 1st? Do you know how to drive a manual transmission? 1st gear is for takeoff's only, from there on, you should be rolling around in 2nd gear if your going 10mph and below. If you REALLY NEED to get in 1st, push the clutch in and tap the throttle to the proper RPM and the gate for first should be open.
Its prob not a joke he most likely just learned how to drive a manuel witch is not a big deal. A friend of mine that i have let drive my car always thinks it nessesary to go into first gear when hes turning a corner or whatever. Like Chili Bowl said 1st gear is for takeoff's only I even use Second Gear at times to takeoff.
1st to me is a pick-me-up gear and it should only be used for starts, i only use first when i go from a complete stop, even rolls most o fthe time i will use 2nd
Thebaws11
Jul 2, 2021 11:36 AM
FRUG35
Sep 11, 2015 03:07 PM
