Trany oil change/gears problem
Old Dec 12, 2006 | 04:43 PM
6spG's Avatar
How many miles do u have?
Old Dec 12, 2006 | 04:44 PM
bobshuai's Avatar
right now i have 38859 miles.
Old Dec 12, 2006 | 04:55 PM
chilibowl's Avatar
That's bull ****. That should be under warranty. You have a 60K drivetrain warranty, so dont let em pull u by your left nut. It is in no way your fault the tranny is acting the way. These 6MT's are known to be ****ty
Old Dec 12, 2006 | 05:01 PM
bobshuai's Avatar
That was what I said, but dealer said clutch isn't under warrnety. If after the tear down and the problem is not my trany instead of my clutch then I will have to pay that $1000 for the labor.
Old Dec 14, 2006 | 09:46 AM
vasqo's Avatar
i thoght we had 70K on trany and motor?
Old Dec 14, 2006 | 10:56 AM
V35 Skyline GT's Avatar
6MT Coupe
My first thought here is the fact you did have your tranny oil changed and have not disclosed that to your Dealer. After the oil change, now you have this problem. It's the tranny oil that Firestone put in there. I would have gone back to them and confirmed if they used the right gear oil.
Second thought is...being now you have the Dealer involved, have them check the clutch pedal engagement and adjust if out of spec rather than tear into it. (But we all know that's not the problem, right? )
Just remember, only you know the fluid has been changed and now have this problem which most likely the cause.
Additionally, sounds as though they are trying to scam you with the clutch thing, but remember, you're scamming them too by trying to get another tranny oil change free and tear into your tranny under warranty. Don't you think they'll think somethings fishy when they check your oil and it's fresh looking, if they haven't already done that without telling you. They ain't that stupid and will (and probably have non verbally) called you on YOUR scam.
And may be why they want to tear into your clutch, deny warranty on that and scam YOU for some $$.
Just remember who started this game. Dealer Service departments can be scam artists and be very good at it. Being they're so good at that, don't you think they're artists at detecting when they are trying to be scammed?
Personally, I would've owned up to the fact about having the oil changed at Firestone and now have this condition.
But that's not your case, so my advice is to own up to it. Pay for another tranny oil change with the right spec'd oil and see if your tranny issue improves.
Just my .02 for the situation you've gotten yourself into.
G/L
-edit-
btw...clutches are wear items like brake pads, they're not covered under warranty, especially with the mileage on your odo and clutch.
Old Dec 14, 2006 | 12:30 PM
bobshuai's Avatar
I am not playing game with dealer but if you do a serach a little bit then you will found out that there are few people that had their 30k serive done by the dealer. As soon as they done their fluid change then they experience the same thing that I have right now. That is why I took it to the dealer and have them to check it. One of the luck guy even got his tranny replace with his dealer. I just felt that tranny shouldn't react like this.
https://g35driver.com/forums/g35-coupe-v35-2003-07/124146-30k-service-mt-tranny-not-shifting-when-cold-wtf.html
Old Dec 27, 2006 | 12:27 AM
bobshuai's Avatar
problem went away after I switch back with OEM oil. I hope this will help.
Old Dec 31, 2006 | 09:11 AM
conesweeper's Avatar
What brand fluid did you use?
Old Dec 31, 2006 | 01:21 PM
bobshuai's Avatar
Oem
Old Dec 31, 2006 | 07:11 PM
What brand fluid did you use the first time I mean
Old Jan 1, 2007 | 12:10 AM
bobshuai's Avatar
I think is called redline syn brand.
Old Jan 1, 2007 | 11:50 AM
6MT Coupe
Glad it got better for you.
https://g35driver.com/forums/showthread.php?t=124146
If you had searched a little yourself, you would have found that this gearbox and it's syncros are very finicky in what aftermarket oil it gets, especially synth and Redline was one that didn't work well from what I've read.
Do a little research and you will find there is a synth brand that does work with no problems, only if you really want to run synth rather than oem.
csdstudio had his tranny serviced at the Dealer, you didn't. His Dealer knew about the oil being changed, yours didn't....lol...in the beginning.
Here's a quote from your thread reference to me:
Originally Posted by csdstudio
Right, that appears extreme. I think the problem is about resolved. Dealer put amzoil in the tranny and diff. Shifts are much smoother and quicker.
BINGO!! There's your answer for which synth oil works.
Glad your Dealer didn't tear into everything, for your sake, only to find mechanicaly nothing wrong and you ending up with a big $$ bill in your hands due to the wrong oil in there.
Old Jan 1, 2007 | 03:49 PM
bobshuai's Avatar
Thanks Doc, thanks for your information only if you can provide it earlier instead after me given out the fact at the end. For your infor OEM trany oil is synth oil also.
Drifter2090
Dec 26, 2015 12:10 AM
derres
Aug 28, 2015 03:27 PM
lemmy999
Jul 25, 2015 12:13 PM
ClwMike
Jul 23, 2015 12:55 PM
