RE short shifer--control socket
Old Feb 25, 2007 | 12:27 PM
  #31
V35 Skyline GT's Avatar
6MT Coupe
Originally Posted by BadBoy06
thats why I called. I read on the Z site alot of guys only using the
1 type. I havent been under there to see how weather/temps would effect
the shifter.
I havent been in the car in a while. Does the boot attach to the
trim piece around the shifter? Do I need to worry about breaking clips?
That pdf file only shows a Z install
Only thing under there in protecting from weather is a rubber boot. It'd physically would stop water/dirt, but not ambient temps and I guess condensation, etc.
That was the hardest part of the install, getting the rubber boot underneath back in it's place/grooves after installing shifter.
The leather boot is attached to the trim piece if I remember right. Take your shifter **** off first before you take the trim piece off with boot attached.
The boot has to slide off the shifter shaft at the top.
And breaking clips, don't worry. I used a flat screw driver wrapped in electrical tape. Wedged underneath trim piece a little off center of center console, got my fingers underneath trim and gave a slight jerk upwards. Popped right up with no problems. Easy as pie. Snaps back in/down when you're all done with install.
Hope this helped.
Old Mar 29, 2007 | 08:35 PM
  #32
RandomHer0's Avatar
This might sound weird but I'm doing the install right now and I'm all done except the shift **** doesn't screw back on, its almost like there was more to the old one that should have come out. Does that make sense? I was comparing the 2 when I had them out and was thinking man the RE is way taller whats up with that...anyone ever have this problem? I think I need to get a new shift **** christ...
Old Mar 29, 2007 | 08:39 PM
  #33
k67p67's Avatar
IIRC, there was a small silver metal collar that needed to be transferred from the old shifter to the RE.
Old Mar 29, 2007 | 08:49 PM
  #34
RandomHer0's Avatar
Dood I found a pic comparing the 2, and mine is jacked. Check it out...
I've circled about how long the stock one is compared to the other, I think the actually threaded piece is still in the shift ****...
Christ.
Old Mar 29, 2007 | 08:57 PM
  #35
6MT Coupe
From end to end, yes it's longer.
From pivot point (ball) to in-cabin, it's the same length.
From pivot point to gearbox linkage, it's longer...that's were it gets it's shorter throw.
My oem shifter screwed back on, but could feel resistance from the old thread lock gunk still in the **** threads.
True, that is an important piece to transfer from oem one.
Old Mar 29, 2007 | 09:04 PM
  #36
RandomHer0's Avatar
Here's an acutal picture of what I pulled out LOL, to me, its ****ed.
Old Mar 29, 2007 | 09:42 PM
  #37
RandomHer0's Avatar
Well I was right, with some patience and ingenuity I managed to get out the top portion from the ****.
Old Mar 29, 2007 | 09:47 PM
  #38
Rphillips6487's Avatar
^^damn thats ridiculous
Old Mar 29, 2007 | 10:27 PM
  #39
RandomHer0's Avatar
Ya bro, I couldnt figure it out. I guess I man handled that thing in half! LOL
So all I did was put the other half in the vice which still allowed me to turn to **** and pull out the top half...
Old Mar 29, 2007 | 10:39 PM
  #40
Curt G's Avatar
Yeah, that's why Infiniti says you need to grab the shift lever with locking pliers right under the top of the boot before you try to twist off the ****. Hey, don't sweat it. The RE is great and you'll never want to go back.
Old Mar 29, 2007 | 11:39 PM
  #41
Cloud_35's Avatar
Umm, stupid question to ask but I noticed how your shift **** is still perfectly fitted into the boot and trim piece. you did remember to remove the shift **** before anything else right? Because it looks like you just yanked everything upwards and the shift **** was still connected to the upper portion of the shift lever, taking that part off of the entire assembly.
Old Mar 30, 2007 | 09:10 AM
  #42
RandomHer0's Avatar
Ya thats what it looks like but thats not what happened, I followed the RE instructions using a cresent wrench and twisted the ****, except I guess instead of un-screwing the **** it broke loose half way down, then I pulled it off thinking Ok that seems short LOL.
No big deal, just put the top portion in a vice and twisted the **** that way, even then it was still a bitch, it was on so tight. Thread Lock I assumme...
Old Mar 30, 2007 | 02:25 PM
  #43
Jason@Riverside's Avatar
the AC800 is the new part number for the newer models...
CD000 is the old number...
And we do have the AC800's available
Old Mar 30, 2007 | 11:25 PM
  #44
BadBoy06's Avatar
found the # for ya
Qty Description Core Price
1 OEM Catalog
4 Part Number: 32870AC800
SOCKET-CONTROL $0.00 $10.65
Sub Total: $10.65
Tax $0.00
hey, I thought I said that already ^^^^^^^^
Freeman186
Sep 6, 2023 10:07 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Row2k
Drivetrain
Dec 27, 2015 04:08 PM
Learned Hand
Oct 1, 2015 09:02 AM
vamarris
Sep 26, 2015 12:56 PM
