What do you think of this clutch flywheel combo?
Old Jun 9, 2008 | 09:48 PM
G35noob66's Avatar
Does this have everything I need to replace clutch? My car is stock and don't plan on racing. Need something comfortable for every day driving and will last little while.
http://cgi.ebay.com/ebaymotors/EXEDY...spagenameZWDVW
Old Jun 9, 2008 | 09:51 PM
Klubbheads's Avatar
for daily driving just stick with stock flywheel. 99% of the after market flywheels are going to have chatter in them..
Old Jun 9, 2008 | 10:00 PM
G35noob66's Avatar
I wouldn't mind the stock flywheel but it's about $1,000 from the dealer. Minus the chatter will this combe last a while? How many miles will it last?
Old Jun 9, 2008 | 10:36 PM
Skaterbasist's Avatar
Retired SuperMod
If I remember, Hexxum001 has this combo.
I'm sure he could give you some input.
Old Jun 9, 2008 | 10:39 PM
Klubbheads's Avatar
just curious how many miles do u have on ur stock one and were u the first owner of the car?
Old Jun 9, 2008 | 11:04 PM
G35noob66's Avatar
I have about 55K miles on the car and I am not the first owner. Not exactly sure how many owners the car had. But I feel the clutch is slipping because when I am driving in 3rd thru 6th gear and give the car a little gas my rpm jumps up and the comes back down and then the car will go. Is that usually a sign of a clutch going bad.
Old Jun 11, 2008 | 08:00 AM
g'dup13's Avatar
That's the same problem i had.. i ordered the act clutch and flywheel combo from z1auto.com. i wouldnt pay no 1000 for a stock flywheel i will put up with the rattle if it happens. good luck.
Old Jun 11, 2008 | 01:32 PM
shabarivas's Avatar
is the ACT much lighter than stock? any increased throttle response? How does the new clutch engage? lemme know...
Old Jun 11, 2008 | 10:15 PM
g'dup13's Avatar
Clutch is been installed so i wouldnt know. As far as wa i read its a heavy duty clutch and suppose to b way better then stock... i'll post when i get the car back.
Old Jun 12, 2008 | 09:53 PM
Graphite's Avatar
Yes, the ACT flywheel is much lighter, due to being a single piece unit. You WILL hear the chatter noise with this flywheel but I got used to it. It goes away when your past 2,000 rpms. It does revv quicker, and since I used a exedy stage 1 on it, the clutch pedal feels like half of it is freeplay, then the rest is all grip. Hope this help out.
Old Jun 12, 2008 | 09:54 PM
Graphite's Avatar
BTW, my clutch started to slip at 50XXX miles and im not the original owner.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
AL8782
Oct 3, 2015 10:26 AM
Jpete
Sep 25, 2015 01:38 PM
bigmike
Sep 17, 2015 01:58 PM
