carbon fiber driveshaft???
Old Mar 11, 2013 | 01:25 PM
  #526
JuicinJake's Avatar
https://www.facebook.com/groups/V35CoupesandSedans/
here is a link to the facebook forum where the group buy that i am hosting is going on.
i think if we can get 4 i can get a little money off of the cf driveshafts, since i already bought one for myself. im trying to find out right now
also, here is a chart for moment of inertia. the driveshaft and wheel can both probably be most effectively modelled using the second one, which is the hollow cylinder:
http://hyperphysics.phy-astr.gsu.edu...imgmec/mic.gif
this sort of confirms what you are stating in terms of wheel weight being more effective at affecting power than driveshaft weight, but ALSO that a reduction in mass in either one will produce a linear change in the moment generated. like i said earlier, i havent been able to get on mine yet because im breaking in my clutch, but it does feel lighter on its feet. ill keep you guys posted as i get further into the break-in.
Old Mar 11, 2013 | 02:22 PM
  #527
mx592's Avatar
Originally Posted by JuicinJake
the difference comes from reduced drivetrain loss... its as simple as that. power holding might be a result of that, but its certainly not the only mechanism for increased power. rotating losses arise from moments of inertia... of which M (mass) and R^2 (radius squared) are the primary factors (along with a shape constant). if everything in the drivetrain weighed nothing, or very infinitesimally small, then there would be no drivetrain loss and a chassis dyno wouldnt read any different than an engine dyno, assuming the same type of dyno and calibration settings and whatnot. since neither situation is possible, the best thing you can do is to reduce it. fwd cars, like the maxima, show greater hp/tq numbers with the same motor/combo than the rwd g35's do. the reason is there is less power lost in the drivetrain. there is less mass tied up in the sum of the rotating parts that ultimately drive the wheels and that is the difference. the engine is making the same power in either case, it just that more of it gets to the ground. if you go put heavy, wide, cast, chrome 20's on your car, you will slow down due to increased rotating mass. if you go put lightweight 15's and race slicks on your car, you will speed up. in a perfect world this would mean a consistent across the board gain, and is best explained like that, but thats not the case in reality, as the loss generated by some rotating components increases with rpm more than others. as i have seen in denchan350gt's dynos with his aluminum shaft, there was a solid 10-20rwhp from 4000-7000 on hill's garage's dyno (i believe dyno dynamics). for reference, this was on a 300rwhp na de combination. i suspect a turbo car would benefit from increased turbo spool times due to the car being more responsive in the lower gears.
Astute observation, although the radius of your driveshaft is far far smaller than the radius of your wheels/tires, so a pound saved on the driveshaft has only a tiny effect compared to a pound saved on the wheels/tires.
10-20 whp would really, really surprise me.
Old Mar 11, 2013 | 04:45 PM
  #528
bluedevils95's Avatar
How about a group buy. I am just waiting on the pricing for the 2nd gen sedan. Got mine measured and they are working it out.
Old Mar 12, 2013 | 01:38 AM
  #529
JuicinJake's Avatar
it did me too, until i saw it on a dyno. he texted me the graph, but i found it online as well. here it is:
http://i48.photobucket.com/albums/f2...81496708_n.jpg
i know this guy personally and he is extremely honest and reputable.
Old Mar 12, 2013 | 01:44 AM
  #530
JuicinJake's Avatar
if you are 2nd gen, jump on this with bluedevel! if you are not, hit me up as i already have a 1st gen group buy going!
Old Apr 15, 2013 | 11:47 AM
  #531
DEMoLITIoN's Avatar
There is a far easier method to get a 1-piece drive shaft. After doing my 6MT swap, I took the automatic driveshaft and had a local shop make a custom 1 piece out of aluminum. They reused the Front yoke and the rear of the shaft then attached it to aluminum shaft. The total price was $270 out the door balanced and everything. This upgrade is a must, after brakes. It beats buying an already made shaft from an online retailer. The money is in the yoke and rear of the shaft which could total a couple hundred $$.
Old May 21, 2014 | 04:24 PM
  #532
murderface's Avatar
First off - Thank you guys for all the research and info in this thread. This is the next step for my G and I am ready to pull the trigger, cash in hand. Long story short carrier bearing is starting to give me some wobble...looks like the rubber is weathered and cracked and i have feel it slowly get worse over time. 2 piece DS assembly has got to go!
So hopefully you guys can help me decide which way to go with my upcoming purchase...
$680.00 - 3.5" Aluminum seems like a decent price and meets same HP rating as CF
$1150.00 - 3.25" Carbon Fiber version seems fair too for the tech lighter/stronger/smaller rotating mass (faster spin up?)
So my questions : What other factors separate the two from a performance stand point? Should i just "Man it up" and go for the CF DL??? It's one awesome piece of hardware but does the material deteriorate over time? Will it start to lose structural integrity with age and weather? My concern being that CF might not last as long as Aluminum but not certain the manufacturing process or level of finish quality. Any insight on this anybody?
Old May 21, 2014 | 04:49 PM
  #533
chiapet15's Avatar
I ended up getting the CF driveshaft by ACPT. I had it installed in Sept. 2012 and have not regretted it since. I've had absolutely zero issues with it. Going to a 1pc driveshaft without the center bearing makes the car quieter at highway speeds and if you have a 6MT it gets rid of a lot of lurching at parking lot speeds in 1st gear. Due to the weight savings, the rear suspension becomes more responsive since you're decreasing unsprung weight by a bit there.
The main reason why i chose CF was for its dampening properties. I wanted it to soak up any drivetrain vibrations, and although I cannot quantify this, I know for sure that CF will do that better. Also, I wanted to make sure I was nowhere near the critical speed of the driveshaft; CF has a much higher critical speed than AL, and I didn't want to risk any standing waves/vibrations developing in the shaft at high speeds, regardless of how small they were.
Also, I thought that the power that would be freed up from lightening drivetrain components (CF shaft is 16lbs, stock driveshaft is 33lbs) with such a small radius would be so small that I wouldn't notice it. However, I was wrong about this. The acceleration of my 2005 coupe may have felt slightly better, but the throttle response was definitely a lot better.
The finish quality of the driveshaft from ACPT (makes the CF) and Power Train Industries (assembles the CF portion to the aluminum yokes) is very good. the CF is covered in a hard, clear coating. Since it's recessed into the body of the car, I wouldn't worry about the CF being exposed to weathering. Mine has been underneath the car for almost 2yrs and is still clean.
Old May 21, 2014 | 05:25 PM
  #534
murderface's Avatar
Thank you! The verdict is in CFDSFTW
Old May 21, 2014 | 05:31 PM
  #535
PLENUMCOUPE's Avatar
Aluminum. Why spend double the money for identical parts made out of different materials. Not understanding the logic here. Ur not in a full blown race car.
Old May 21, 2014 | 05:44 PM
  #536
murderface's Avatar
Says who? I named her Murderface... she has one end goal. Murder faces. We all dream big. My dream includes building the best platform for the most power, staying true to the VQ, and when the stars align go for the full Vaydor Kit install and then who knows?!?!... I'm looking for a unique approach to creating a car with as much "Show" as it has "Go". This piece of hardware to me answers that calling. When it comes to a mans G swagger to each his own. My .02 most of us out there are still trying to decide which direction we want to go...
Old May 21, 2014 | 05:53 PM
  #537
chiapet15's Avatar
I wanted to play it safe. I don't remember the what the exact critical speed of AL vs CF was for a fixed diameter and length of driveshaft was, but i do remember that the CF shaft's critical speed was at least 3x that of the AL shaft. Also, the coupe driveshaft is pretty long by most standards, which further decreases the critical speed and explains why the stock shaft is a 2pc; Nissan was likely avoiding critical speed issues with having a single, long steel driveshaft. Since I don't know whether there would be vibration issues (even ones that cannot be felt) with having such a long AL driveshaft, I chose to have as much margin as possible. I plan on driving this car for a very long time (until i can afford a new Porsche 911 4S), so I need the drivetrain to last as long as possible and cannot tolerate any vibrations that could shorten service life.
Speaking of safety, if in a serious accident, the CF driveshaft will break up or shatter with much less force than the AL, which reduced the risk of the shaft penetrating the passenger cabin or catapulting the car.
Old May 21, 2014 | 06:05 PM
  #538
murderface's Avatar
From what I was told the "other" company that used to sell Aluminum drive shafts noted that critical speed was at 170. In a few unique cases car owners were tuning their cars to go well above 7500 RPM redline and 170mph and this raised a safety concern. They did not state when they would have a DL option available but noted that they are testing a "beefier" option. (Seriously that's what the dude told me) As far as The Drive Shaft Shop and ACPT i have not seen any notes on critical speed for Aluminum.
Old May 21, 2014 | 06:13 PM
  #539
chiapet15's Avatar
When I was doing my research, I also spoke to that other company, and the beefier version of the AL driveshaft was also in "progress" at that time (this was in July 2012). I got tired of waiting, and I figured that they would make the AL beefier by increasing the thickness of the shaft walls, which would decrease the weight savings when compared to CF.
Although at 170mph the vibrations would create a safety concern, the minor vibrations will start at a much lower speed; over time, this could pose reliability issues in the transmission and differential.
Old May 21, 2014 | 06:35 PM
  #540
chiapet15's Avatar
Hope you enjoy the CF shaft. To this day, it's my favorite (because of improved throttle response and getting rid of the lurching) and most unique mod.
If you're looking for other weight reductions, I'd recommend the following in addition to the usual removal of spare tire/tools, losing weight (driver), lightweight sport seats, etc:
1. Braille GU1R lithium starter battery: 6.4lbs vs. my old 50lbs Sears DieHard Platinum AGM lead-acid. Removing that much weight that far up in the chassis does wonders for turn-in response and body roll. This lithium battery has none of the problems associated with the small, lightweight lead acids. I've left my car sitting in the garage for 2 weeks and it started up just fine.
2. StopTech front BBK, ST-40, 332mm rotors (Reference is stock 2005 G35 coupe). Doing the front saves the most weight, the rear actually adds a slight amount of weight, but the braking improvement is well worth it
Front Stoptech Caliper (ST-40): 7.8 lbs
Front Stoptech Caliper Bracket: 1.8 lbs
Front OEM Caliper : 15 lbs
Net weight Savings per front wheel from caliper upgrade: 5.4lbs
Front Stoptech Rotor (332mm): 17.8 lbs
Front OEM Rotor : 21.8 lbs
Net weight Savings per front wheel from rotor upgrade: 4lbs
Total unsprung weight savings per front wheel from BBK upgrade: 9.4lbs
Rear Stoptech Caliper (ST-22): 4.2 lbs
Rear Stoptech Caliper Bracket: 0.8 lbs
Rear OEM Caliper : 6.6 lbs
Net weight Savings per rear wheel from caliper upgrade: 1.6lbs
Rear Stoptech Rotor (328mm): 16 lbs
Rear OEM Rotor : 13 lbs
Net weight gain per rear wheel from rotor upgrade: 3lbs
Total weight gain per rear wheel from BBK upgrade: 1.4lbs
