carbon fiber driveshaft???
Old Aug 6, 2008 | 09:31 PM
sheplex02's Avatar
Exclamation carbon fiber driveshaft???
ok so i know ive seen them on someones car(either G or Z) just cant remember who.. does anyone know who sells them for the G35?
Old Aug 6, 2008 | 09:40 PM
bigwilly's Avatar
The Z comes with a composite drive shaft stock.
Old Aug 6, 2008 | 09:47 PM
G35Ian's Avatar
http://www.dynotechengineering.com/
Google "custom drive shafts"
Old Aug 7, 2008 | 02:04 PM
OCG35's Avatar
sedan is 2-piece... no one sells a one piece CF, but I found a place in HB (So Cal) that will do it - they are reputable and were referred to me from commercial industry connections... its $1100 but they need to destroy OEM drive shaft in order to get proper specs and whatever else they do to make the CF one... I wasn’t willing to lose my OEM shaft which is the only reason I haven’t done it yet.
There is a post out here somewhere about it and I posted their info - if anyone wants to contact them I'll look up the info in my records at home tonight or this weekend.
Old Aug 7, 2008 | 07:01 PM
shipsaeki's Avatar
i doubt the weight difference is much. it already has an aluminum one.
Old Aug 7, 2008 | 07:06 PM
sheplex02's Avatar
oh.. ok.. i was unaware of these facts and im glad i was corrected.. thank you all..
Old Aug 7, 2008 | 07:10 PM
OCG35's Avatar
for the sedan it’s as much about one piece (instead of 2 piece) as it is weight... but, a CF one piece would weigh substantially less than OEM.
Old Aug 7, 2008 | 07:47 PM
AboostedG's Avatar
http://www.acpt.com/consulting.html
Old Aug 7, 2008 | 08:02 PM
OCG35's Avatar
^^^ yep. Thats the place I was mentioning... how did you find out about them? Was it a post I made?
Old Aug 7, 2008 | 08:26 PM
OCG35's Avatar
Originally Posted by HomieG35
PM member "meatbag" he had one made.
Edit: (there is no way to make this sound non-dirty... so here it goes)
I've held meatbags CF shaft and it is VERY lightweight. I'm taking one hand curls all day... it's like a feather - pretty cool.
is meatbags a sedan or coupe?
Old Aug 7, 2008 | 11:36 PM
OCG35's Avatar
Coupe
OEM coupe is one piece right? If its 2 piece, I'm in!!!! That means they've already got the specs and dont need to detroy one...
Old Aug 8, 2008 | 01:22 AM
DaveB's Avatar
The coupe uses a two piece driveshaft and it appears that using a one piece unit is not a good idea because the OEM 2 piece driveshaft system employees three univerisal joints. That tells me that there is quite a bit of movement between the front and rear subframe chassis mounts. If you go with the one piece unit, you'll run the risk of having the shaft contact the underbody which could be very dangerous. The driveshaft is already tucked high up in the tunnel therefore extending the angle of driveshaft movement by getting rid of the other univerisal joints could be a really bad idea. There's good reason why Nissan used a two piece shaft in these cars. It would have been cheaper to use the system like the Z, but clearly the 8" longer wheelbase in the G results in more shaft movement.
Old Aug 8, 2008 | 02:47 PM
OCG35's Avatar
theres is one area that would need to be cut to clear a one piece shaft... I already looked it over and discussed with TechnoSquare...
as for Nissan having a good reason = well I guess that could be said about the entire car and therefore modding wouldn’t be advantageous at all... but some of us like to try different things...
now that I know a shaft has been blueprinted, I might go ahead and get one... if it’s no good at least I still have the OEM to fall back on.
