Better shifts in 06c MT ??
Old Sep 17, 2008 | 08:11 PM
randyc's Avatar
Just wanted to know if the MT has been improved on the 06Gc . Heard alot of complaints of grinding gears on previous models.
Old Sep 18, 2008 | 01:01 AM
GreenGoblin's Avatar
The goblin resurrection
I have no complaints in my 04
Old Sep 18, 2008 | 02:41 AM
DEMoLITIoN's Avatar
If you cant find em'...Grind em'
Old Sep 22, 2008 | 01:51 PM
Rphillips6487's Avatar
no complaints with my 06 6mt coupe at all..maybe those who are complaining need some driving classes
Old Sep 22, 2008 | 01:55 PM
redlude97's Avatar
The rogue engineering short shifter is supposed to smooth out shifts quite a bit
Old Sep 22, 2008 | 02:18 PM
fbpem1's Avatar
early model 03's had problems grinding due to synchro design, it has since been worked out.
Old Dec 3, 2008 | 10:51 PM
DauntlessG's Avatar
I have an 06 6MT Coupe and I'm getting my 3rd tranny (second replacement within 10k of each other) replaced under warranty (as we speak), due to grinding when shifting directly from 4 to 6...this has nothing to do with "bad driving" just a bit of technical ignorance on our part.
here's a link to a previous thread that may help you out a bit, you can also refer to your manual or ask mike@riverside.
https://g35driver.com/forums/tech-07...th-gear-2.html
simply put...dont skip gears, our trannies arent made for it.
Old Dec 4, 2008 | 05:33 PM
civic4982's Avatar
I had the same problem with grinding from 6th to 4th and they replaced my tranny due to damaged synchros.
Picture Share
Feb 4, 2018 12:41 PM
RWDguy4238
Sep 30, 2015 12:13 AM
blnewt
Sep 25, 2015 01:48 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
