G35 5AT Lag in Manumatic UP Shifting
Old May 24, 2004 | 10:24 AM
bsgoren's Avatar
Does anyone know why there seems to be a slight lag in the G35's shifting while in M mode? When I use the manumatic mode in our 2003 Infiniti FX35, it responds very quickly as I shift (almost immediate change of gears as I shift up or down). However, in my 2004.5 G35, there is about a 1/2-1 sec. delay from the time I shift UP manually...it's a bit annoying. I haven't noticed this delay when downshifting (say from 4th to 3rd).
Anyone know what the deal is with this and if my dealer can correct it (with an ecu reset or transmission adjustment perhaps)? Thank you.
2004.5 Infiniti G35 Sedan 5AT Black/Willow - Prem, R. Spoiler, Navi, Infiniti Sport Wheels
(basically Sport Package w/o stiffer suspension), Darkest Tint (this is FL afterall), Z Tube, K&N Filter<P ID="edit"><FONT class="small"><EM>Edited by bsgoren on 05/24/04 07:35 AM.</EM></FONT></P>
Old May 24, 2004 | 02:58 PM
GurgenPB's Avatar
Re: G35 5AT Lag in Manumatic UP Shifting
Get GordGee's grounding wires, including the number 9 and 10 (ECU and TCU wires). I believe you will notice a difference in shifting firmness and quickens and better general response.
Gurgen
Old May 24, 2004 | 03:14 PM
G35Five_O's Avatar
Just a quick observation about the wiring. I just added a 5 wiring kit and I noticed that the vehicle shifts in the red and does not hit the rev limiter. The vehicle seems to shift hard too. Sometimes the slip light comes on, at WOT, when the vehicle shifts from 1st to 2nd.
I am not complaining but its an observation I made.
I have a 2003.5 sedan auto.
other mods: z tube, pop charger. after market muffler.
Old May 24, 2004 | 03:48 PM
marcg's Avatar
I have noticed this same problem on my sedan in MM mode. How does the grounding wires affect the [censored] firmness? Getting the AT to shift firmley would be a huge improvement.
Marc
Old May 24, 2004 | 04:23 PM
G35Five_O's Avatar
This was just an observation and I was hoping that someone could explain this to me. Could this be the ground kit I installed or if it is how I drive on an daily basis and the transmission is just adjusting.
Sorry I couldn't help.
Old Jun 3, 2004 | 11:02 PM
marcg's Avatar
Anyone have any updates on this?? I would like to know if there is a way to firm up the shift points.
Marc
Old Jun 3, 2004 | 11:28 PM
DaveO's Avatar
I second Gurgun's recommendation.
GordGee's 10-wire Ground Gear system worked out well on my 2003 AT Sedan. IMO, it's a great modification... and I started out a unbeliever.
From a very good source... the G35 AT Sedan's TCM program calls for a 0.4 second "luxury" shift. While in initial testing, the TCM and ECM actually corrected the modified valve body's shift characteristics back to stock parameters.
DaveO
2003 G35 AT Sedan / DP / Willow / Premium / Sport
350Z Air Duct, Eng Cvr & T-Stat / Stillen CAI / Crawford Plenum
GG 10-Wire Kit / TS ECM / E-Fans
Street Edge TC / B&M Cooler / Stillen Exhaust
Old Jun 4, 2004 | 01:08 AM
bsgoren's Avatar
I'm bringing my car in for service on Monday. With 950mi. now on the car, it seems like the upshifting delay isn't quite as bad as it was, but it's still noticeable. My Infiniti service manager told me over the phone that the car's computer is still "in learning mode" and adjusting to my driving/shifting habits...is this correct or a bunch of b.s.?
Can Infiniti do a TCU update or reset to resolve the upshifting delay? Or, do you think they would add ground wires to the ECU and TCU?
What could I ask them to do to eliminate this delay? I feel like there's something wrong with the transmission and this shifting delay should be corrected by Infiniti under my warranty. Anyone know? Thanks.
Old Jun 4, 2004 | 07:55 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
I find that the time delay varies. It seems to hold longer the harder you accelerate & at higher revs.
I find I have to shift about 500 revs early, to hit the shift points I want.
Also I find I still have a brain cramp from my manual trany days.
I find myself wanting to ease up on the gas when it shifts.
I really miss the manual trany, but my left knee is to screwed up to evan conside driving in daily traffic...[img]/w3timages/icons/frown.gif[/img]
<font color=blue>04 Silverstone G35, Prem, Aero
ES100 225/45-18 front 245/40-18 rear
Painted calipers, side marker signals
Debadged INFINITI</font color=blue>
Old Jun 4, 2004 | 03:42 PM
gspot35's Avatar
Did you get your tranny update to the 04 trany mapping? I had mine changed and it made a significant improvement. Did you notice anything more from the ground wires other than shifting? Couldn't I just add one from the battery to the TCM?
03 Sedan ~ 5AT ~ aero ~ 19x8" Axis wheels ~ Garnet ~ premium ~ NISMO body kit ~ clear front corners ~ Stillen Cat-back ~ Injen CAI ~ Crawford plenum
Old Jun 4, 2004 | 08:05 PM
DaveO's Avatar
gspot35,
Which TCM software upgrade did you get? Could you provide the part number and build date of your G?
I believe my 2003 AT Sedan was the one of the first to get the TCM's AL004 program update. This was the latest program that was guaranteed to work in my beta tester car (as Gurgen puts it). Since then Gurgen has had his done.
My hat's off to Justin at EverythingG35 and Infiniti of Scottsdale for doing this mod. They're great mod friendly people.
Don't really know how well one TCM ground wire would work. In my subjective opinion, Gord Gee's 10-wire Ground Gear System works very well. I understand and appreciate the amount of R&D as well as the quality he puts into his systems.
DaveO
Old Jun 5, 2004 | 02:50 PM
lucidazn's Avatar
Can you guys post a link for Gorgee's Ground kit? I did a search in Yahoo but no results came up. Thanks.
Old Jun 5, 2004 | 07:19 PM
Gordgee's Avatar
Administrator
Sorry, I still ahven't decide whether or not to do a GroundingGear™ website yet, since my distribution is normally through authorized dealers and a distributor. Just PM me.
<font color=blue>[i]GroundingGear™ Equipped </font color=blue>
Old Jun 6, 2004 | 03:56 AM
robertc81's Avatar
I just got a Stillen Grounding Kit today and installed it. It works wonderfully. I really do recommend purchasing a grounding kit. My MM mode shifts quicker and I feel a quicker throttle response.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
Frostbite91
Jul 27, 2015 05:25 AM
laksjd84
Jul 24, 2015 05:12 PM
nervseele
Jul 17, 2015 11:21 PM
