Matic-J
Old Jan 2, 2009 | 04:48 PM
  #46
geronimomoe's Avatar
Originally Posted by Lucky-G
Haha no embarrassment here brother!
Well, I plan to do a drain and fill and then drain and fill again after around 3k miles.
That's the Honda way. In Honda's if you want to do a change of the ATF, their suggestion is to do drain, fill, drive for a few minutes, and repeat 2 more times. This will basically replace at least 80% of the ATF..
Honda does not recommend doing a flush on their trannys.
Old Jan 2, 2009 | 05:14 PM
  #47
Lucky-G's Avatar
*shrug* I don't know, all I know is I'm sure it's time for a drain/fill at the very least, because my tranny's been acting atrocious. Studder-type slip when engaging 2nd at around 3500-4000 rpm (roughly half-throttle) and 5th seems to "fall" into gear instead of glide every once in a blue moon at toe-throttle.
joedaddy1
Aug 31, 2010 06:06 PM
pianofrk4
V36 Engine, Exhaust, Drivetrain & FI
May 12, 2010 01:55 PM
ty423
Other Cars
Aug 15, 2009 03:09 AM
gwhiz35
Aug 9, 2007 02:44 PM
