Best replacement clutch/flywheel?
Old Feb 9, 2009 | 05:18 AM
340WHPG35's Avatar
I think my clutch, and probably synchros are about done. I figure to upgrade the clutch and flywheel when figuring out what's wrong with the trans.
What kind of clutch/ flywheel is good for a "moderate" streeet ride? I'll probably never go over 400WHP in this car, so I don't need some hard core set-up. I don't mind a little chatter in trade for the performance.
Also, does the 2003 6MT have a LSD as OEM equipment? I figured it must have some kind, but it often doesn't feel like it.
Any advice/ experiences are appreciated!
Old Apr 12, 2009 | 10:31 PM
WINTERDEVILG35's Avatar
i like z1 motorsports for my engine.but to answer bout the LSD....it has a VLSD.if you dont know what that it then i wont tell you.ill tell you how to find out though cause i dont like to hear if i have this or that i like to know where to find out....which is your manual in your glovebox.lol.GL.
Old Apr 13, 2009 | 12:03 AM
gabe3d's Avatar
JWT or ACT are good. ACT costing more and having a little less chatter then the JWT in my experience.
If i'm not mistaken then the 03 only has LSD, the VLSD started with subsequent years.
Old Apr 13, 2009 | 12:15 AM
JD_AND_DA_G_RIDE's Avatar
Personally I'd recommend going with a moderate clutch and resurfacing your stock flywheel...I went with like a stage 1 Luc clutch which is a slight improvement over stock that handles somewhere round 400WHP which is way more than what I'll ever need. Good luck.
Old Apr 20, 2009 | 10:52 AM
SPEC-01's Avatar
There are a number of clutch and flywheel options available for the G35. Because the G comes with a stock dual-mass flywheel, a unit that isn't easy to surface properly, I would recommend the use of an aftermarket single-mass flywheel. There are steel and aluminum variants available. The Steel option will be more like the stock flywheel in regards to weight, feel and performance.
As for a clutch recommendation, I would go with a stage 2 (or similar). Our stage 2 utilizes a Kevlar disc material that is more durable, generally longer wearing, and still very drivable. Capacity for our Stage 2 (part number SN352) is 390lb.-ft at the crank. I hope this info helps. Let me know if you have any further questions. Thanks,
Old Apr 21, 2009 | 09:16 PM
Iron_Man's Avatar
In regards to the synchros issue, I had the same problem. I took it the dealership and let a tech drive it who agreed that the synchros were bad. The dealership replaced the transmission under warranty.
11bEMT
May 27, 2022 03:13 PM
ara777
Aug 15, 2018 04:11 AM
snic09
Nov 8, 2017 01:46 PM
miata007
Aug 17, 2015 04:36 PM
35reilly
Drivetrain
Aug 6, 2015 12:40 AM
