Clutch noise at high RPMs -- clarification?
Old Mar 19, 2009 | 03:07 PM
[Rush]'s Avatar
G35 6MT
I purchased an '05 G35 6MT Coupe yesterday. Love the car, but considering where I came from with my last car (lightweight, turbocharged 4 cylinder) .. I wanted to make sure that what I'm experiencing isn't the warning sign of a tranny and/or clutch about to take a crap.
When I'm on the gas in the upper RPM range and push in the clutch to shift, I get noise. It is NOT the gears grinding (the shifter goes smoothly from one gear to another), and there's no problem with the gears catching or anything like that. It's just .. noisy and loud.
I've done some reading on it, and most people seem to make it sound like it's normal -- the 6MT's just have a noisy transmission, apparently -- but I wanted to double-check for my own reassurance. Is it REALLY normal? Is it nothing to worry about so long as I can continue to shift smoothly without any gear grinding issues? When should I start to be concerned?
Old Mar 19, 2009 | 05:37 PM
jakz0rz's Avatar
If it's like a clunking/shutter noise in the rear end, during fast shifts then I get it too. Especially during 1st-2nd gear.
Old Mar 19, 2009 | 10:16 PM
Defs's Avatar
I get a muted hum/vibration from the pedal. I also get some vibration from the clutch pedal when everything is cold. I'm thinking it's related to the throw out bearing. I'll bring it up to the dealer, but I imagine they'll tell me it's normal. Mine is an 06 btw.
Old Mar 20, 2009 | 12:52 AM
Reidonly's Avatar
The throwout bearing in these things is noisy as all hell when you push the clutch in and then let off the pedal. The tranny can seem a bit notchy on occasion too, mostly going in 1st and 2nd gear. It is not an uncommon thing lol.
Old Mar 22, 2009 | 10:42 AM
GTreeFive's Avatar
I used to have an audi smooth as buda. When i first got my G i was really perinoid about it too, I noticed the vibration at high rpms. Its normal these cars look smooth but the manual trans is pretty unrefined in comparison to the germans.
High revs brings added fibration, almost like it can handle spinning that fast or something. It may also be something with the revup engine thats louder at high rpms. Mine is an 06 6MT.
Old Mar 22, 2009 | 11:22 AM
[Rush]'s Avatar
G35 6MT
Thanks for the input! .. I've never dealt with such racket before, and I came from a spastic Mazda, LOL.
Old Mar 22, 2009 | 04:36 PM
djamps's Avatar
Yep it's normal (both fortunately and unfortunately I suppose!)
Old Apr 21, 2009 | 10:24 PM
jpnelson1978's Avatar
mine sounds kind of whiney when i press the clutch at high rpms.. my mustang sounded nothing like this. must be the difference in a 6cylinder to a v8
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
yankeefix
Lighting
Aug 24, 2015 04:12 AM
tehmoonrulz
Jul 19, 2015 10:44 PM
006
Intake & Exhaust
Jul 19, 2015 04:30 PM
Jadenkid22
Jul 14, 2015 12:33 AM
